Subwoofer POP!
Tanquen
Tanquen Posts: 27
edited March 2009 in Troubleshooting
What would cause the subwoofers to pop when they turn on and off? Any way to just keep them on?
Post edited by Tanquen on
  • Tanquen
    Tanquen Posts: 27
    edited February 2009
    I have a Polk PSW140 that don't do it but an Infinity Cascade Fifteen that will.
  • TheMARPATNinja7
    TheMARPATNinja7 Posts: 150
    Anything from cheap electronics to static eletricity. My old stock pioneer sub popped everytime I touched the back (design flaw).
  • ohskigod
    ohskigod Posts: 6,502
    thats about it, try powering down the sub last if you havent done it. sometimes the sub will pop if you turn the procesor/reciever off first. worth a shot. I leave my sub amp on, but it's a DIY job with a sub plate amp made for that. check the manual to see if leaving your on is kosher or not
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • gsquared
    gsquared Posts: 11
    edited March 2009
    any other ideas? i seem to have a similar problem (intermittently)
  • Mike21
    Mike21 Posts: 252
    edited March 2009
    My Sunfire Sub pops when they go on from standby and into standby (no on/off switch). They're sitting on carpet so I'm pretty sure its static electricity. The Sub didn't do this when I put a 1/2" MDF board underneath (which I removed becuase sound was better w/ sub dorectly on the carpet).
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • ChrisD
    ChrisD Posts: 101
    edited March 2009
    Mine does very slightly. I have it on carpet too.
