Help with static
SideEffect34
SideEffect34 Posts: 4
edited February 2009 in Troubleshooting
First things first: Here is my set up:
Reciever: Onkyo TX-SR606
Front Towers: Polk TSI300 (x 2)
Center: Polk CSI A4
Subwoofer: Polk PSW 125
2 Rears: Polk OWM3 (x 2)
I had installers come out a couple weeks ago to install and hook up everything, but they used Optical and Digital cables for my PS3 and cable box. I wanted HDMI for audio so I just hooked that up today. Now, I notice static coming from the center and the 2 front towers. I asked on another forum and they said to check your speaker cables and I did and I think they're ok. So does anyone know how to get rid of it? If you need anymore info or anything let me know. I would greatly appreciate any help. Thanks.
Post edited by SideEffect34 on
    F1nut Posts: 50,828
    The obvious would be a bad HDMI cable.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    If it happened right after you installed the HDMI cable...that's probably what's causing it. I'd look into getting a different HDMI cable.
    By the way, Welcome to Club Polk.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • metal83
    metal83 Posts: 1,219
    Man......You paid someone to hook up your stuff? Isn't that part of the fun?
  • comfortablycurt
    metal83 wrote: »
    x2
    I love the headache that's involved in hooking up all of my gear. It makes it more personal.;)
  • MSALLA
    MSALLA Posts: 1,602
    metal83 wrote: »
    Ya, I don't like other people playing with my toys. ;)
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • SideEffect34
    Well, I don't really think it's the HDMI that is a problem. 1. They are new high quality Monster cables and 2. I tested it and it still makes the noise even when the Cable box and PS3 is off. So when the Onkyo is the only one still on, it still does it. So I'm thinking it must be the speaker wire cables or settings in the Onkyo. I'm not sure if anyone is too familiar with the Onkyo recievers, but would there be a setting internally that could change it? :confused:
  • tcrossma
    tcrossma Posts: 1,301
    There are no settings that I know of that cause static -- this is a hardware or interference issue of some kind. Given the timing of it occurring when the HDMI cable was installed, that would have been my first guess too. And the supposed high quality and/or manufacturer in no way guarantees you against having a bad cable.
    I'd just go through a process of elimination here, unplugging everything and then plugging things back in one at a time and see if you can make sense of it all.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
    F1nut Posts: 50,828
    Your word for the day is oxymoron.
    Did you change anything else when you added the HDMI cables?
  • comfortablycurt
    So you didn't have this issue before you installed the HDMI cable right? It started right after the installation of the HDMI cable? It sounds like the HDMI cable.
    Just so you know...Monster Cable isn't exactly synonymous with quality. It's better defined as "crap that costs way to much". There are much better options out there. All that aside, it's entirely possibly that you got a defective cable. It happens fairly frequently.
    monoprice, as mentioned above would be a good choice.
    You might also look into Bluejeans Cable.
  • tcrossma
    None of those links work. But coiling speaker cables can cause issues, yes. Easy enough to test that theory though -- just get in there and start experimenting and see what changes.
  • tcrossma
    I wouldn't think the "coiling" done on those cables would be causing you any issues.
  • Face
    Face Posts: 14,340
    Lasareath wrote: »
    As F1nut mentioned it must be the HDMI cable.
    Sorry to do this to you:
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=3992&seq=1&format=2
    Well, it's not that bad, return the other one and buy this one from MonoPrice.
    Welcome to Club Polk!!!
    Lasareath
    I agree. Return that cable back to the retailer and save yourself $100 by buying a cable from the link above.
  • joeparaski
    joeparaski Posts: 1,865
    Perhaps something was knocked loose when the hdmi cable was installed? Check your connections.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Mike21
    Mike21 Posts: 252
    My guess is defective HDMI cable. Try a Monoprice and see if that works.
    If not, the problem might be the AC power, possibly the wall outlet. As previoisly posted, try an outlet in a differnt room. In fact, you might try this first before spending money on another HDMI cable.
    Let us know what happens.
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
