Center channel distortion.
MSALLA
My center has an intermitten distortion problem. The big problem is every time I start to look into it, it stops. It dose not happen when I play music in 5 channel mode. I switched out my blue ray to my 2900 and it still happened.
Dose anyone know what would cause this. It's down to the AVR, amp, speaker or one of the wires. Any help would be great.
I am guessing that it could not be the TV? Or could it.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880
Post edited by MSALLA on
What gauge speaker wire are you running to your CC? It wouldn't be the TV because the Lsic is magnetically shielded.
I'm not trying to be a wise guy, but you might check to make sure none of the speaker wires are touching each other.____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
The speaker wire is just some 16ga monster from BB. It's not touching any bare areas and the ends are in Banana clips. I am wondering if it the cable box. I noticed the sound thru the TV was breaking up just alittle last night.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
Ok, I was having the same problem so I wired all my speakers up front with 14 gauge, it helped a little bit. Out of curiousity I'd hook everything up with bare wire and ditch the banana clips, just to see if this is all because of a dud clip. Just a random thought, but thats something I'd try.
