how to replace db5251 inductor?
jso123
jso123 Posts: 1
edited February 2009 in Troubleshooting
While checking connections to determine why
my front left speaker was not working,* I noticed that the copper coil of wire inside the crossover was rattling around . The crossover was not mounted securely in the door and I suppose the movement caused the inductor to snap off. Strange.
Anyway, is there a way to access the other side of the circuit board so I can sodder it back on? I built a crossover once before and so I think I can fix it.
I am sure that the warrantee has expired and appreciate any DIY tips to fix it.
Scott
* Turns out that left front chanel of my Pioneer head unit is bad.
Post edited by jso123 on
    F1nut Posts: 50,828
    Scott, you might have better luck getting an answer to your question in the "On The Move" section towards the bottom of the main page.
