Tape Loop Out Question
Lsi9
Lsi9 Posts: 616
edited February 2009 in Troubleshooting
Does a tape loop output act as a Home theater bypass of sorts? does the volume of an amp affect a tape loop out?
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP
Post edited by Lsi9 on
  • schwarcw
    schwarcw Posts: 7,341
    Greetings!
    The volume control will not affect the tape out volume level. Hovever, these are good source to connect a subwoofer for two channel audio. You will have to adjust the subwoofer level from time to time depending on how often you vary the sound level from one extreme to the other (soft to loud). I found this arrangement to work very well in some of my vintage two chanel systems where I wanted a subwoofer connected to an old receiver.
    Carl
  • Lsi9
    Lsi9 Posts: 616
    I mean to eventually hookup a receiver's L/R channel pre outs to my integrated amp. What I shouldve asked is does a tape in get affected by an amps volume?
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Lsi9
    Lsi9 Posts: 616
    Too bad my amp doesnt have a tape in just regular aux in
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Lsi9
    Lsi9 Posts: 616
    Use a receiver's L/R preouts during 5.1 HT use into my integrated amp with receiver driving center and surround channels while my 2 channel is driving the L/R volume controlled by the receiver
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Lsi9
    Lsi9 Posts: 616
    yes for 5.1 sound
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Lsi9
    Lsi9 Posts: 616
    I am not sure u get what I mean...I am using an integrated amp and would like to use the power from it not the receiver
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • comfortablycurt
    comfortablycurt Posts: 6,745
    It sounds like he's wanting to use the integrated to power his mains(as an external amp of sorts) and use the receiver to power his center and surrounds. All at once though for movie watching.
    Not sure if that would work or not though...
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Lsi9
    Lsi9 Posts: 616
    Yes I guess a Home theater Bypass is what I need, Thanks guys! expecially Keiko :)
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
