Audioquest website crashes my computer!
Erik Tracy
Erik Tracy Posts: 4,673
edited February 2009 in The Clubhouse
If I go to Audioquest's website - some of their Analog IC products crash my computer :mad:
Any IC in the DBS series causes my computer to do a soft reset.
Same with their Price List.
I'm running MS Windows 2000, IE ver 6 and Adobe Flash v9.
Same thing if I browse using Firefox and Flash v9.
That's just bad web design.
Post edited by Erik Tracy on
  • polkie4life
    polkie4life Posts: 231
    Works ok on mine. I even downloaded the pricelist etc :confused:
    In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
    http://www.polkaudio.com/forums/showcase/view.php?userid=86838
  • Erik Tracy
    What OS and browser version are you running?
  • shack
    shack Posts: 11,154
    I never have any problems on their site, even years ago when running MS ME (an absolutely awful OS). I just now went to it with no problems. I'm still running XP Pro and IE7.
  • Erik Tracy
    shack wrote: »
    Thanks for checking...I'm running a whole version behind you for both the OS and browser.
    Still...a good web design should not cause a computer to reset.
  • Systems
    Systems Posts: 14,873
    You might try checking on a new version of video drivers, those have a tendency to cause issues especially if theres flash running....
    Testing
    Testing
    Testing
  • Erik Tracy
    Lorthos wrote: »
    AH! Good call - cuz this happens if I'm running IE or Firefox. Could be that calls from the flash are causing a video memory problem.
    Doncha just love computers? HT is just as complicated. :confused:
    Thanks,
    Erik
  • hearingimpared
    hearingimpared Posts: 21,136
    That's because your PC is digitally biased against analog!:D
  • polkie4life
    Erik Tracy wrote: »
    The latest version of FF and windows XP
  • Refefer
    Refefer Posts: 1,280
    Eww, all flash. There's nothing on there that couldn't have been done faster, and better looking, than in traditional html/javascript. Once again, they do it in flash to someone else's detriment.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • obieone
    obieone Posts: 5,077
    If you can hang on until late summer, windows 7 is expected to be out by then. Don't upgrade to Vista anything!
  • Erik Tracy
    obieone wrote: »
    Windows 7?
    I guess that Microsuck decided to drop the fancy code names for their OS...probably a good thing as folks were making up alternate names for their OS...
    NT = Not Trustworthy
    XP = Extra Problems
    Vista = Virtually impossible stability/troubled always
    I hate OS upgrades....
  • hearingimpared
    It is my understanding that you are only going to be able to upgrade to Win 7.0 from Vista. This is according to a Dell sales rep. My cousin just bought a laptop with XP on it and it came with a Vista disc so he can upgrade to Win 7.
    I don't know how accurate this info is so I would check it out.
  • Erik Tracy
    So Windows 7 is an upgrade only?
    What happens if you buy a brand new computer after Win 7 comes out?
    Does the outlet first install XP then upgrade to Win 7? That is completely idiotic. :confused:
  • mmadden28
    mmadden28 Posts: 4,283
    Try another browser first. (Safari, Firefox, Google Chrome) If you still have the same problem, then look into updates for the rest of the OS or hardware (video, etc).
    If you don't have the problem with the other browsers, then you can concentrate your troubleshooting to IE (patches, plug-ins, any other add-ons).
    ____________________
    Pool: Atrium 60's/45's
  • hearingimpared
    Erik Tracy wrote: »
    I don't believe it is an upgrade only. However I was told that to upgrade to 7 you must first have Vista. As I said before this came from a Dell rep.
  • Polk user
    Polk user Posts: 311
    I actually heard the opposite. If you are running VISTA you cannot "upgrade" to Windows 7.
  • shack
    shack Posts: 11,154
    From everything I've read, you can upgrade from Vista/XP or do a clean install regardless of the OS.
  • mantis
    mantis Posts: 17,201
    Erik Tracy wrote: »
    Your computer is not high end enough to connect to the Audioquest website. You have to upgrade everything then your good.
    LOL, sorry to hear.
    Dan
    Dan
  • phuz
    phuz Posts: 2,372
    Re-install/update Flash.
    Here: http://get.adobe.com/flashplayer/
    Holy crap I just saw your specs. Make sure you have SP4 on windows 2000, and maybe try IE 7. The flash update may fix it as well.
  • Erik Tracy
    mantis wrote: »
    LOL, sorry to hear.
    Dan
    You're joking...of course, right :confused:
    Forcing users to do a system upgrade so that they are compatible with a vendor website is going about webdesign backwards...been there...I've done my own websites and have changed code to be backwards compatible.
    I leave to door open that I have to upgrade a video driver. Drivers are the bane of system compatibility - but a system upgrade is like tossing the baby out with the bathwater...or whatever that saying is... ;)
  • Refefer
    Erik Tracy wrote: »
    Hmm, you seriously might want to think about upgrading your OS at the very least in the near future. First of all, driver updates are unlikely to continue coming out for the NT operating system. Secondly, win2k is definitely not up to date on security patches. I think you probably want to keep usernames/passwords to yourself as well as credit card info out of the hands of malware ;)
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
