Moffed/boxed sound on center speaker
olilugo
olilugo Posts: 405
edited February 2009 in Troubleshooting
Hi all,
What can I do to correct, enhance the sound out of my center chanel speaker?
I just purchanse a new receiver and when watching moviews using my BDP, I notice the conversations/sound out of my center chanel to be very boxy and muffled.
I am using a very basic setup:
BDP ->(hdmi) -> vsx-1018HK -> TGA-5200 Amp -> speakers.
Center chanel is a polk csi5.
I did change the BDP to be direct so I do get the TRUE-HD display on my reciver.
Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire
Post edited by olilugo on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    What's the location of the center channel? Is it free standing or is it in a cabinet? If it's in a cabinet that could be contributing to that a lot.
    You might also try adjusting the crossover point on it, or turning up the overall level of the center channel as well.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • TNRabbit
    TNRabbit Posts: 2,168
    Fried tweeter or crossover?
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • olilugo
    olilugo Posts: 405
    Thanks for the feedback guys,
    I hope it is not a fried tweeter or crossover, the sound is more open on my old receiver. vsx-812k.
    Granted on the vsx-812 I was using coax for sound, the new is using hdmi for sound.
    I played a bit yesterday and I can get better results just ajusting my speakers using a SPL metter and getting rid of all the EQ by deleting all memory of the results when I first run the MCACC setup.
    It is getting better...
    I am woundering My I getting to the end of my spekers capabilities or is it the receiver that is just not that good enough.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
  • TNRabbit
    Do you have the receiver in the proper mode? (i.e., 5.1 Dolby Digital, DTS, etc.)?
    TNRabbit
    Sunfire TG-IV
  • olilugo
    olilugo Posts: 405
    when playing a Blu-ray movie, the display says: Digital True-HD. when playing a regular DVD it does say: Dolby Digital.
    I am hoping I can play with it more this weekend.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
  • TNRabbit
    What do you have it plugged into on the back of the receiver; got a pic?
    TNRabbit
    Sunfire TG-IV
  • olilugo
    olilugo Posts: 405
    Sorry I don't have a picture but the back is very simple.
    2 connections in: (HDMI)
    1. from BDP
    2. from DVD
    1 connection out: (HDMI)
    1. to TV
    5. connections out :(IC)
    5. out to external AMP
    1. connection out: (IC)
    1. to SUB
    mains and center channel are inside a cabinet. I do have a pic of the cab.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
  • TNRabbit
    So you have HDMI into the Pioneer receiver then Analog I/Cs to the Amp? WIll the Pioneer pass info received in HDMI out through the analog outputs properly?
    Try hooking another speaker up to the center cables & see if it's the speaker or something further upstream.
    TNRabbit
    Sunfire TG-IV
  • olilugo
    olilugo Posts: 405
    that is a good questions . I think it is time for me to read the maual some more...
    I will try your suguestion for changing the speaker and see if it has any effect.
    One of the main reason I choose polk and especifically these speaker set was because they are front firing speakers. the ports are in the front so it was ok to put them inside the cabinet.
    Thanks for the help.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
  • apphd
    apphd Posts: 1,514
    You might also want to get the center angled so it is pointing down a little instead of over your head. Then try the MCACC again or do a manual cal again with a meter. Also is this muffled sound only on the BDB?
