SR-124 DVC Clicking
bemis23
I've recently installed a full set of Polk SR series in my car. Everything sounds great, but I have a small problem with the subwoofer. When I'm near the woofer cone there is a "clicking" sound that seems to emanate from directly behind the woofer cone. It's not signficant, and totally in audible in the cabin but it worries me.
I've heard that bad spark plug wires can cause similar clicking sounds, though typically through the tweets or mids.
Has anyone else had a similar problem?
Basic build information:
Eclipse CD-3200 HU
1x SR-124-DVC in a sealed box (1.38cu ft, without the woofer installed)
Powered by Soundstream Tarantula TRX1000D (800wt RMS x1 into 2 ohms, running at ~450wt)
Eclipse CD-3200 HU
Post edited by bemis23 on
bump for help
if you dont get a response, give the 800 customer service line a call.
look under the support drop down menu above
I would try tightening the mounting screws, dont laugh, it might be that simple. worth a shotLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
