In what order should I upgrade my system?
asd1234
asd1234 Posts: 30
edited February 2009 in Electronics
Current System
What I want
Fronts: Rti A7's
Rti A9's
Center: Csi A4
Csi A6
Sub: Bic Acoustech VK-12 1000/watt
Rears:Rti Fxi A4
Fxi A6
Receiver: Denon 4308ci:
Amp (more power): Emotiva
Rpa-2,Xpa-2, Xpa-3, or Xpa-5
Standard Remotes
Harmony one Remote
Any suggestions would be greatly appriciated. Even if it is something I did not list on my want side. I'm not looking to go crazy on spending, just a step up from what I have right now. I use my system 70% TV/Movies, 30% Music/Games
Post edited by asd1234 on
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2009
    With that setup, I would only get the CSiA6. Maybe a stereo amp for the A7's.
    SOPA
  • asd1234
    asd1234 Posts: 30
    edited January 2009
    Ricardo wrote: »
    That is the exact thinking that I had. I think the A6 can be had from polk direct for $199. For the amp I am leaning towards the RPA-2.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    You already got a nice system so I'd say an external amp then the csi a6 second and third dual subs.
  • danger boy
    danger boy Posts: 15,722
    edited January 2009
    you should go for an amp.. then later upgrade the rest... the amp will tie you over till you can complete the rest.
    PolkFest 2012, who's going>?
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    CSiA6
    2 channel amp
    At least to start with, that would probably get you the best results.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited January 2009
    I would get some type of source, so you can use the equipment you listed. Then a good universal remote.
  • Hawkeye
    Hawkeye Posts: 1,313
    After a source, room treatments.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • george daniel
    george daniel Posts: 12,096
    + 3 on the source
  • mantis
    mantis Posts: 17,411
    First off thats already a really nice well balanced system.
    I didn't see a Blu ray player so a BDP05fd from Pioneer ELite is in order. Then I would sell that Denon receiver and get a Sc07. This will cover your desire for better sound and more dynamic range.
    On to the center channel, yes upgrade that right away. Center channel is the most important speaker in the system and the best place to spend the most money. Never cheap out on the center.
    Last but not least, what kind of wire are you wired with? This is another place to look at to make sure you are using the correct wire so the system can do it's job.
    A universal remote should have already been purchased. I don't see why anyone would want to use the factory remotes and juggle them all over the place. Do yourself a favor and get the universal remote. It's just as important as a badass center channel.
    So get the center channel and remote first. Then replace the Denon, then lets talk wire. I don't see the need to upgrade the main speakers, yours are already incredible. I really like the 7's. I kinds in secret fell in love with them. I was shocked in there performance. I sat and listened to them a few times before Tweeter closed. I could not believe the difference from years ago to this model year. I even had to pull in the salesmen to show my findings. I made fanboys out a few of them.
    Good luck with your upgrades. Spend that money and make yourself happy.
    Dan
    Dan
  • NewHTguy
    NewHTguy Posts: 584
    Relative the to cost of the system, the center is the cheapest/easiest upgrade. If you listen to a lot of two-channel, then get the amp first. I believe a two or three channel amp should be sufficient, given the nice AVR.
    From some posts I've read in the past, the A9's may have a different and not necessarily better sound than the A7's. Not saying you wouldn't enjoy them, but I would be sure to audition them before making that kind of upgrade.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • Marty913
    Marty913 Posts: 760
    asd1234 wrote: »
    You stated you listened to movies and TV 70% of the time so I'd approach it from that angle. You have a best-buy editor's choice receiver (Sound & Vision) delivering over 125 clean watts into 5 channels. I would not put an amp at the top of your list.
    The center channel upgrade is an immediate payback item so go there. The universal remote is immediate payback so that's next.
    You didn't mention your DVD source but if it is DVD and your display is HD-capable then I'd get with a good BR with above average upconversion. The Panasonic BD-35/55 get high marks and don't cost a lot (as does the Sony 350). Once again, very little $$ and it's based on what you do the most of.
    I like the sub (12", 1000 BASH amp, Kevlar driver) so I'd keep it.
    Depending on your room, treatments may be in order. You didn't mention the setup so it may not be a priority. Worthwhile looking at.
    Only then would I look at the amp; and then the speakers.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • asd1234
    asd1234 Posts: 30
    Wow!
    Thanks for all of the great suggestions. I'm going to call polkdirect tomorrow and see if they have any Csi a6's in stock. That seems to be on the top of everyone's list. The only reason I didn't get it first is because at the time i didn't know it would be that much of an upgrade, and i got the csi a4 for $76.00.
    Right now I am using a PS3 80 gig as my blue-ray player. For me, it does a fine job de-coding audio, up-converting video, and I also like to stream the occasional movie from my computer.
    What type of universal remote are you guys using. I was thinking about getting the harmony one. I can get it on ebay new for $179-$189. Any other remotes I should be looking at?
    If I got the Emotiva Rpa-2, how much of an upgrade do you think it would be for my two fronts?
  • thsmith
    thsmith Posts: 6,082
    H1 is an excellent remote, don't know about buying on ebay, I would check the river the same price.
  • Sherardp
    Sherardp Posts: 8,038
    Upgrade center, add second sub or sell the BIC and go for SVS PB13U, and finally front projector/screen.
  • Marty913
    Marty913 Posts: 760
    asd1234 wrote: »
    I'm using older Home Theater Masters (MX-700) but I wouldn't recommend them unless you like programming. I've heard great things about the H1 though.
    If you're going to go the amp upgrade route I'd do a 3-channel at least. Why create a potential imbalance issue across the front sound stage.
    TT = Audio Technica
