PSW 505 rattle
tytus45
Need some help here. Psw505 has a rattle in it. When i place the sub on its side the rattle goes away. Im thinking it may be the lead wires from the amp to the driver. Do I take the amp off the sub and try to secure the wire? If so any ideas on how to keep the lead secured? I work the sub quite abit and do not want to have this issue keep coming up...any ideas out there?
Post edited by tytus45 on
Take the amp out carefully. If it's the lead wires, just epoxy them to the wall, or use some soft filler material (whatever they put in the sub box) and wrap it around the wires.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Thanks for the input. The epoxy is drying right now...by the way nice vintage polk...Mine is similar...rt800's mains. cs400 center. Rt35 rears. dcm sw150 and psw505 powered by H/K avr85...
