Harsh highs with RTi10s
dcacc
dcacc Posts: 45
edited January 2009 in Troubleshooting
Does anyone else who owns RTi10s experience harsh highs? I feel like I've tried everything, and I can't seem to soften them.
I'm powering them with a Carver TFM 35, 250 watts per channel, which I just added recently. It has made a huge overall improvement in their sound -- I mean, night and day -- over my Onkyo 805, which I'm using as a pre-amp.
I'm using good cables (14 gauge). They are bi-wired. I've tried tackling room acoustics -- I recently put down an oriental carpet with a thick pad, which covers about 80 percent of the floor. And I hung drapes over our sliding glass doors.
But still I'm getting a lot of sibilance and just plain unpleasantness in the highs.
Is this a characteristic of the RTi10s? Has anyone else struggled with this? Any suggestions for what to try next?
Post edited by dcacc on
  • suprafantx
    suprafantx Posts: 249
    edited January 2009
    I have the same problem with my RTi10 before. Lsi series will solve that problem. Still some people really enjoy the harsh high.
    Living room
    Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
    Player: Oppo 95.
    Amps: Bryston 4B SST, B&K Ref 200.7 S2.
    Pres: B&K Ref 50 S2, Paraound P5.
    Subs: Dual Rythmik F15HP subs.
    Man Cave
    Speakers: Martin Logan Vistas.
    Player: OPPO 105.
    Preamp: B&K Ref 50 S2.
    Amp: B&K Ref 125.2 S2
    Sub: Rythmik F12.
    Sub management: SMS-1.
    Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
    Room treatment: GIK Room Kit #1.
  • Lowell_M
    Lowell_M Posts: 1,660
    edited January 2009
    I can't stand that generation of RTi's because of the harsh highs. Not sure what you can do to help it out, although in my experience the Carver TFM's are a little on the bright side as well.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • dcacc
    dcacc Posts: 45
    edited January 2009
    I have a chance to by some LSi7s for around $300/possibly less. Do you think they would be an improvement in my large family room? Paired with my HSU STF3, which is a pretty beefy sub.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    dcacc wrote: »
    Large room no. If your leaning toward the LSi series in a large room I would be looking at the LSi 15's. If you do a lot of music listening with your rti 10's then you may also want to look at POlKS older vintage speakers SDA's or Monitors.
  • timmythugs
    timmythugs Posts: 71
    edited January 2009
    My rti12's are set to negatives in high frequency and that seems to do the trick. Plus, lsi to me seemed awfully bright when I heard them. It is all opinion though!
  • pablo_rodz
    pablo_rodz Posts: 331
    edited January 2009
    I have RTi10's and dont consider the highs to be an issue.:confused:
    Don't know if it matters, but I power them from my Pioneer Receiver.
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2009
    You need a "soft-sounding" amp :). I tried my RT1000p with Adcom GFA-5400 and Carver TFM-24, and they sounded too bright/harsh on the higher end.
    Switching to Harman Citation 24 really softened the highs. :D
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • steveinaz
    steveinaz Posts: 19,538
    edited January 2009
    I'm assuming your bass/treble are set at 0dB correct?
  • dcacc
    dcacc Posts: 45
    edited January 2009
    Yes, they are/were at 0. I've been experimenting with bumping the treble down a bit, which seems to help a bit but leaves vocals sounding kind of recessed.
  • steveinaz
    edited January 2009
    The Lsi series are more laid back in the treble, as well as Energy's Connoisseur line of speakers.
  • danger boy
    danger boy Posts: 15,722
    edited January 2009
    it was talked about several years ago.. that the RTi line of speakers were not a good match for Onkyo gear = harsh highs. the old timers around here will remember discussing this at length.
    the conclusion was for some odd reason pairing RTi speakers with Onkyo receivers was deathly shrill highs.
    PolkFest 2012, who's going>?
    F1nut Posts: 50,828
    edited January 2009
    Sibilance can be a pain to tame and you made a good start with the room treatments. Adding some tubes to the mix will help also, but those speakers are just bright to begin with.
    What are you using for a source and are you listening to music or HT?
  • dcacc
    dcacc Posts: 45
    edited January 2009
    I'm listening to music, using my Oppo DV 980H as a CD player (it's quite good with music). How does Harman Kardon pair with the RTi's? I have a line on a HK AVR for a reasonable price.
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2009
    I've got the RTiA7's (next gen of RTi10) running with a Carver TFM-25 amp and Carver CT-Seven pre-amp and they sound fantastic. No sibilance problem at all. Even when I switch them over to the Yamaha receiver and any source they are not overly sibilant. Could be the HK as a pre. Even though when I bought the A7's I first listened to the RTi10's which were considerably less expensive due to the new line coming on and I found them harsh and fatigueing in the highs. It's why I spent the extra and went with the A7's.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • dcacc
    dcacc Posts: 45
    edited January 2009
    I don't know if it's placebo effect or what, but I just switched back to basic hookup instead of bi-wire and they seem to have calmed down. But at this point, I've been tweaking for hours and I think my ears are just too fried to tell the difference. :(
    F1nut Posts: 50,828
    edited January 2009
    dcacc wrote: »
    Try something different.
    Good move.
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2009
    dcacc wrote: »
    Try a different CD player, maybe even an HD-DVD player. Toshiba's XA1 and XA2 had excellent decoders built-in.
    Regarding Harman, I really prefer when my RT1000p towers are hooked up to the separate amplifier (Citation 24), not to the HK AVR, which is driving center and surrounds. When I had Adcom GFA-5400 hooked up to the mains, they sounded so harsh on the highs, I was getting tired after listening to the music in less than an hour.
    Carver TFM-24 was better than Adcom, but not as soft and smooth as Citation, so I moved it to a 2-channel setup to drive Maggies :).
    I used to have a monoblock (Outlaw M200) driving my center, but it did not make much of a difference on that channel.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • Ern Dog
    Ern Dog Posts: 2,237
    edited January 2009
    I had the same problem when I had Rti10's. In stages, I added a warm sounding B&K amp and a tube pre which helped. Upgrading my source from a $200 Onkyo DVD player to a $500 NAD cd play also helped. But in the end I decided to upgrade the speakers. It really depends on your ears and how far your are willing to go to have the sound you want. If I could do it over again, I would have started with upgrading the speakers first.
  • thsmith
    thsmith Posts: 6,082
    edited January 2009
    Try some Owens Corning 2" 705 acoustic panals behind and to the sides of your mains.
    Friend has the 10s and when he added more power to them and treated the walls it helped tremendiously.
    Try running Audyssey in flat mode and see what that does for you. Are you using all 8 measurements in Aud? If not this will help.
    Good Luck,
