RTi A5 or RTi A7 and do I need an amp?
I can't decide being a n00b at this and all. This is the setup I'm thinking of
Fronts: RTi A7
Center: CSi A4
Surround: RTi A1
Subwoofer: eD A2-300
AVR: Onkyo 706
Question is do I need to have a power amp with this setup? I like the sound of the RTi A7 but an amp is a bit more than I wanted. Probably be the XPA-3 but that's $500 more than I'd wanna spend. I like the bass of the RTi A7 but some say i could get the RTi A5 and the sub could handle that. Also if the RTi A5 would sound better since it's less power hungry if I don't want the amp would that be a better option? Being a n00b and all maybe a power amp is a bit much for a first time surround sound system and I don't know if I'll be able to tell the difference if I got one. Any advice would be a great help! Almost ready to pull the trigger but just can't decide. Thanks!
Fronts: RTi A7
Center: CSi A4
Surround: RTi A1
AVR: Onkyo 706
Post edited by Alkaar on
Never heard the A7's so i can't say much about em.
The A5's can be driven without an amp fairly easy. What you will notice if you run a amp is a large jump in the bass department and the highs may lay back a bit. For me this is what happened anyway.
Also the A5's will make some decent bass but again i'm running a amp so they do so a little better.
What i have read alot is that the A5's are better in the midrange department because of the two midrange drivers vs the single on the 7's. Just something to think about.
I run my A5's with a sub and honestly it's more than enough bass. IMO.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
Jeez you guys respond fast! Much faster than the Polk thread over at avsforum. Yea I had read a lot of recommendations for the CSi A6 over the CSi A4 but when I went over to J&R to listen to them it was a bit hard to tell the difference. Though they were running the fronts as well so it was hard to tell the difference though I haven't received any bad advice yet!
So is there really an advantage to having your fronts with more bass if your subwoofer is adequate enough? I know there was a thread here about that. If that's true I might rather go with the A5's to have better mids and let my subwoofer pick up the lows that the A5's can't reach.
I suppose I could up my receiver a little bit but that wouldn't get as much juice as the XPA-3 would. Also this is mostly going to be 10% movies 90% gaming if that helps. Seems like running the speakers, TV, amp, and AVR would be a bit nuts on the utility bill as I do play a decent amount of games on it and I'll probably use it for plain TV watching too since the TV speakers are garbage. -
I have the A-7's and the A-1's on order. I already have the Csia6, all powered by a Yamaha 663. I heard the 7's before purchase and loved them, but i will be adding an amp, probably 5 channel. Do yourself a favor and get the a6 like Kex suggested if you go for the 5's. Awesome center! Good luck.Receiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Front L/R: POLK Rti-a9s':D
Center:POLK Csi-a6
Rear surround's:POLK Rti-a1s'
Sub: Klipsch Synergy sub-12
Sony Kdl-46w4100 46" LCD
PS3
Audioquest type 4 wiring. -
The RTiA5s with a good sub is a great combo:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I personally have some Rtia7's, and I love them, was still enjoying them without using my sub! Which is a monster, but cylinder subs rock. But I have an a4 center, I got it long before I got the a7's, so is it worth trading up for an a6 center (plus it's so big)? Cash is strapped now so would it make that big of a difference?
Vankor, I personally noticed a marked difference in clarity for dialogue and vocals with the a6. I upgraded from the csi3 center in preparation for the arrival of my A-7's. The a6 being the recomended center for the Rtia line. Good highs and lows too.Receiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Center:POLK Csi-a6
PS3
The RTi a5's and a good sub and you'll be good to go. Doesn't need a amp to push them but adding a external amp will make them sound a lot better.
I second that...Leroy hit the nail on the head. I love the a5's even my wife pulled out all the old movies and watched them over the weekend and she was loving it. Nice mid range, but I would surely say get a good sub. I tried it with out a sub and those a5's where weak in the low bass bad.Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
Velodyne DPS-12 (Sub)
EMOTIVA XPA-5
:cool::p;):) -
TouchOfEvil wrote: »Never heard the A7's so i can't say much about em.
Very well put. My A5's with a sub on just my receiver was nice. I just added an Acurus 2X150 and the improvement in sound is exactly as you have stated above. -
If your 90% gaming i don't see any reason to go with the A7's honestly. The 5's with a nice sub to handle the low stuff will be more than enough. Plus you don't spend the extra green on the amp etc. So instead upgrade to a bigger better sub lol j/k.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
another +1 for the A5 w/ sub. I like them a lot more than the 7's (actually I'm basing that more on the rti10 to be honest, but the A7 is the newer version of the 10, same drivers slightly different cabinet). Like was said- a5 + sub will give you plenty bass without giving up midrange.
Personally I also like the csi a6 over the csi 3 which again is the older model of the a4. The dialog seemed more 'full' to me with better definition over a wider range. I don't know if it would have been worth the retail difference in price to me, but I got a great deal on a barely used refurb and it was more than worth it to me. -
I have A7s and Onkyo 706 with RTi4 as surrounds. You dont really need more power for those speakers. You can take "Kex" Opinion, or keep the A7s. It sounds great. By the way seems you dont want 7.1 ch so far. Set the system Bi-Amp. I tried with my Onkyo 706 and A7s and the voices are more clear, bass sounds great too.
BTW I have a Marantz SR6003 now, And Im testing both systems. I will post tests later. But to be honest if you get Onkyo 706 for $575 or less, and the Marantz for $995 take the Onkyo 706. its not much difference.Panasonic 65" Plasma
Pioneer SC81
PS4 BluRay / Memorex BD-Player
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Monster Power HtS 1600 Power Line Filter/Conditioner -
TouchOfEvil wrote: »If your 90% gaming i don't see any reason to go with the A7's honestly. The 5's with a nice sub to handle the low stuff will be more than enough. Plus you don't spend the extra green on the amp etc. So instead upgrade to a bigger better sub lol j/k.
That is true most of the lows I'll be hearing are explosions and what not. Maybe some occasional low bass song but that isn't the focal point of my viewing. I was actually looking at the Onkyo 806 and it's only $60 more for an advertise 30 more WPC which I'm thinking about now. -
To talk some tech the frequency ranges of the below are...
RTi A5: 30Hz-27kHz
RTi A7: 20Hz-27kHz
eD A2-300 sub: 18Hz-100Hz
It almost seems like if I go with the A7 it would make my sub worthless and as Vankor stated the A7's sound fine without a sub because they can go low enough on their own. Even though the A5's might not have as large of a range as the A7's, the A5's with a sub probably beat out the A7's. Think I'm leaning towards A5's with the sub this way I'll get my decent lows and I'll have an extra mid-range driver. Could always get another A2-300 if I want more bass.
Now if only polkdirect would stock up on some more A5's.
I'm anxiously awaiting my a5's(friday). I got mine for 282 each(black) from amazon. I thought that was a great deal. Can't wait to get them going. Good luck with yours.Onkyo 606 AVR
PS3
Fronts Polk RTI A5
Center Bic America DV-62CLRS
Surround Onkyo Satelites
Samsung LN52A550 TV -
RTi A5: 30Hz-27kHz
RTi A7: 20Hz-27kHz
I wouldn't go off them specs. The RTI'a7 's will not hit 20 hz. For movies you'll need a sub regardless of withever speaker you pick. -
Great deal. Let us know how you like them. The hardest part is waiting. -
its true what leroyjr1 says.. Even with your A7s you will need a sub for movies. For music is nice, but anyways, a sub in music will help alot too..Panasonic 65" Plasma
Pioneer SC81
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Did some more research and more on the A5 side. Does seem like if it's mostly movies/games I can let my sub handle that and let the front handle the mids and highs which is what they're suppose to do. Seems like A7 would be more for music since you can just listen to music at 2.0. Also I read that most suggest I should cross at 80 hz which would mostly defeat the purpose of having the A7's. I'll let everyone know which one I do end up going with. Still got some time before I can officially pull the trigger.
HEY HERE'S MY TWO CENTS, HAVE YOU CONSIDERED GOING WITH A DIFFERENT BRAND OF RECEIVER. I HAVE BEEN DOING RESEARCH ON THIS AND THERE IS A BUNCH OF DIFFERENCE IN BRANDS. RIGHT NOW I THINK THE MARANTZ 5003 ON EBAY NEW IN THE BOX IS A BETTER RECEIVER THAN THE ONKYO AND I OWN A 705. FROM ALL REPORTS MARANTZ IS AWSOME AND IF YOU HEAR IT OMG. AND THE SPEAKERS ARE RIGHT ON WITH THE RTi'S. HOPE TO HEAR FROM YOU SOON. GOOD LUCK!!!!!!
Oh by the way, the 5003 new in the box is 799. No tax and free 2nd day air.
Yes it's true.
Figured I'd post an update. Finally decided on the following.
Fronts: RTi A5
Center: CSi A6
Surround: RTi A3
Subwoofer: eD A3-300
AVR: Denon AVR-2809CI
I went to J&R for one last listen and yea the midrange on the A5 is better but you really gotta pay attention and the bass ain't so bad honestly so decided to go the A5. Upped the surrounds and center and subwoofer. Also didn't like how the Onkyo 706 and 806 were having blue dot issues and the Onkyo 876 was butt expensive. Found the Denon AVR-2809CI for $861 shipped with some PMing. Now's the waiting game for the speakers to show up on polkdirect! Man pushing my budget but rather buy something I like than to have buyer's remorse! -
Wow...I think you're the first person I've ever seen report an improvement through bi-amping with an AVR. Most people have reported that it wasn't worth the cost of the extra speaker wire...lol
External amplification is good for any speaker though. Most AVR's don't really have an efficient enough power section to really drive most speakers. They can do a good job with it most of the time, but speakers will always benefit from better cleaner power. Sure the A7's, don't "need" more power, but they will benefit very very much from it. External amps will help open up any speaker though. It's not necessarily about having more power...it's about having better power.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
