PSW10 - Blowing Fuses
Taustin
Taustin Posts: 4
edited February 2009 in Troubleshooting
In replaced the 2A 250v slow-burn fuse which was blown. The second I plug this PSW10 in the fuse blows. What do you suggest I do to correct the problem?
Taustin
Post edited by Taustin on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2009
    Try a different outlet, and check the power cable. You have probably already done that but it's all I can think of for quick fixes. Other than that may need to make a call to Polk, or maybe Eric will have some ideas.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Taustin
    Taustin Posts: 4
    edited January 2009
    Thanks for the suggestions. I have tried what you suggested but I am still blowing fuses. It must be internal to the curcuit board or transformer. Still at a loss for how to troubleshoot this problem. Other suggestions?
  • Pauly
    Pauly Posts: 4,519
    edited January 2009
    Contact CS. Sounds like the amp is bad. Prob gonna have to send the amp in for replacement/fixing. Long as you have reciept and was bought from auth dealer should be free.
    Pauly
    Life without music would
  • Taustin
    Taustin Posts: 4
    Polk repaired the subwoofer. It was a blown amp, but it cost me $60, since I purchased it more than 3 years ago. I should recieve it the weekend. Cheaper than buying a new one. Stillpleased with Polk!
