Denon AVR-2807 Audio Help
shopman1
shopman1 Posts: 2
edited January 2009 in Troubleshooting
I have a center speeker, front right and left, back left and right and a sub. I dont seem to get a good sepration on the sound left and right or back, it all sounds the same. I have tried all the settings nothing sould as good as my car for god sake. help
Post edited by shopman1 on
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2009
    I would hope that it wouldn't sound like a car system. Your system should sound cohesive & solid & unless watching a movie, you shouldn't be able to tell what is coming out of which speaker.
    Calibrate all of your speakers for matched volume, sit back & enjoy.
    Welcome to CP Shopman.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2009
    Also, make sure your speakers are a good match for each other. What speakers do you have? Are they all the same manufacturer or are they a mix of a bunch? Probably won't make a huge difference, just a thought.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • shopman1
    shopman1 Posts: 2
    edited January 2009
    Thanks for the input, much appriciated.
    I have all Boston speekers. Two mini's in the back, two bookshelf in the front and the 100 amp subwoofer in the corner.
    shopman1
  • wutadumsn23
    edited January 2009
    Are they close together, or are they spread out? Depending on the type of system, the size and ability of the speakers, and setup it may not give you the best sound quality. I am not familiar with Boston's HT speakers, but I know they make decent car audio speakers. Maybe you are expecting to much from them?? Sorry I can't be much help, just trying to make my best guess.
    HT Rig
    Blu-Ray- 80 GB PS3
  • zx_toth
    zx_toth Posts: 417
    edited January 2009
    Make sure you dont have some weird 'Audessy' option engaged. I have a Denon 2807 and had the Audessy feautre on and everything sounded flat, once I disengaged it all sounded blissful.
    You wont get good seperation if they are too far apart. Do a search on speaker set up or speaker seperation on the official THX or DTS website which has some nice information on speaker spacing. Often people have their speakers too close together. Read up and re-arrange and report back.
    Let us know if anything helps, if not we'll keep throwing out random pieces of advice :-) You may want to give us some more information including taking a picture of your set up so we can see if it is placement issue.
    Zsolt
