Starting my SDA restoration
Bigerik
Bigerik Posts: 149
edited January 2009 in Vintage Speakers
Finally getting around to doing some restoration work on my SDA 1B's. First step:
Ordering some RDO 194 tweeters.
Next step: Gonna poke around here and figure out how exactly I want to rebuild the crossovers with good quality components. Not gonna try to reinvent the wheel. Seems that a lot of you guys have done a good job on the crossovers already with great results.
Of course, if anyone has any thoughts or recommendations, they are much appreciated.
Will post here as things develop.
Post edited by Bigerik on
  • fbm211
    fbm211 Posts: 1,488
    edited January 2009
    Sonicaps are best for crossover rebuilds.A good alternative is dayton 1% that you can get at parts express.The sonicaps available at soniccraft.com will run around twice as much.And Mills or mundorf resistors are great.(Mills are a little warmer sounding than mundorfs I hear)And you can always go dayton caps on the low pass and sonicaps on the high.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Well, looks like the start of the project is a few weeks further away than I thought. Will not be able to get the tweeters from Polk Canada for another 2 plus weeks at best.
    F1nut Posts: 51,778
    edited January 2009
    Hey Erik, when you're ready I'd be glad to help answer any questions you have.
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Thanks Jesse.
    Right now, I don't even know what questions to ask! :)
    My plan is to do a stock restoration with better quality modern parts (194's and Sonicaps). If there is a better way, please let me know.
    F1nut Posts: 51,778
    edited January 2009
    Ok, I take it you know what cap values you need and that Mills 12 watt resistors are recommended. There are some very large cap values in your speakers and Sonicap's don't come that large, so you might want to look at Solen for those. Dayton may be another choice, but I don't know if they come that large.
    Some other tweaks while you're at it. Remove all the 750pF bypass caps and do not replace them as they are no longer needed. Remove the polyswitches, if you're not in the habit of clipping your amp(s) and replace each one with a jumper.
    Another tweak that I like to do is apply Dynamat Extreme to all the driver baskets and the PR baskets. This stops any ringing of the stamped steel baskets.
    Have you considered replacing the binding posts?
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Thanks Jesse.
    Hadn't thought about the binding posts at all. Probably worthwhile to do. The ones there are not that great. How about the interconnect? You thinking that one too?
    Is going with the 198 as compared to the 194 a mod I should be thinking of? As Polk Canada is closed until Monday or something, I have a few more days to decide which way to go with tweeters.
    I saw references in other threads stating that you recommend doing stuff one step at a time. What order do you recommend doing it?
    I thought I found the thread with all the cap values I need. Gotta dig that up again.
    Did some reading tonight, and realized I need to do more reading.
    F1nut Posts: 51,778
    edited January 2009
    A lot of folks upgrade the interconnect and report good things. You can buy new blade/blade connectors here, https://www.alliedelec.com/Search/ProductDetail.aspx?SKU=750-3200&SEARCH=P%2D302%2DCCT&ID=&DESC=P%2D302%2DCCT
    With your speakers you can only use the RD0194-1's.
    Nah, all of this stuff is tried and true, so knock yourself out. :)
    What you will need in total.
    Caps:
    (2) 12uF Sonicap
    (2) 4.4uF Sonicap
    (4) 34uF Solen or other (you could use 17uF Sonicap's in parallel, total of 8)
    (2) 85 or 83uF (can't make it out) Solen or other
    (2) 130uF Solen or other
    Resistors:
    (2) 2.0 ohm 12 watt Mills
    (6) 2.7 ohm 12 watt Mills
  • Face
    Face Posts: 14,340
    edited January 2009
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Caps:
    (2) 12uF Sonicap
    (2) 4.4uF Sonicap
    Resistors:
    Actually, didn't I see some guy on here insisting that the SL2000 was a better tweeter? :D
    Those are some big **** caps in there. Judging by the threads I have seen on some of the other SDA's looks like there were some pretty big differences in cap values.
    In the enquiring minds want to know category, I did see some people talking about adding a 5.8 or something cap and going with the 198's. Is that not a workable option for me or just not something I want to bother with?
    Thanks for the info.
    Erik
  • Face
    Face Posts: 14,340
    edited January 2009
    Bigerik wrote: »
    For SDA's, I believe that only applies to the pin/blade 2B and P/B CRS(+?).
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Face wrote: »
    Gotcha!
    F1nut Posts: 51,778
    edited January 2009
    Bigerik wrote: »
    Yes you did and now he's gone. :D
    Face is right, that will not work with your speakers.
  • davidk0512
    davidk0512 Posts: 157
    edited January 2009
    Caps:
    (2) 12uF Sonicap
    (2) 4.4uF Sonicap
    Resistors:
    The "85 or 83 uF" should actually be a 65uF, it's hard to read, so I checked with Ken a couple of months back when I was getting ready to order parts for mine.
    David
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    :D
    Thanks. So much SDA info on here that it is hard to sort out sometime what applies to what.
    Someone should write a book about them... :)
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    davidk0512 wrote: »
    Excellent!
    Thanks much.
    BTW, is there a thread here showing pics of someone doing the rebuild on a 1B? Found threads on almost every other SDA it seems....
  • Schurkey
    Schurkey Posts: 2,122
    edited January 2009
    Well, this thread is just about perfect.
    I need to "investigate" my 1Bs; they sound SO much better when the SDA interconnect is NOT connected. I suspect something is wrong; although all the drivers seem to be connected properly and working.
    I can solder; but I'm not experienced in electronics so I've been waiting for someone else to do it and post results.
    Have at it, Bigerik. Post lots of photos when you're done!
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Schurkey wrote: »
    Oh Sure!
    Put all the pressure on me! :)
    Will do!
    F1nut Posts: 51,778
    edited January 2009
    davidk0512 wrote: »
    Thanks for clearing that up, David. I would have never thought that was a 6.....LOL
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Agreed.
    I squinted hard at it too.
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Caps:
    (2) 12uF Sonicap
    (2) 4.4uF Sonicap
    (2) 65 uF Solen or other
    Resistors:
    Checked with my local Solen dealer, and they said the closest they can get is a 36 uF instead of a 34 and a 68mF instead of a 65.
    Just how picky are the SDA's?
  • Face
    Face Posts: 14,340
    edited January 2009
    Within 5% is golden.
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    Face wrote: »
    Excellent.
    Thank you sir.
    Looks like I am in business.
    F1nut Posts: 51,778
    edited January 2009
    Erik, you can narrow it down a bit.
    Use a 16 + 18 to get 34uF
    Use a 33 + 36 to get 66uF
    http://www.partsconnexion.com/catalog/CapacitorsFilm.html
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    You are right. Of course.
    (except for the math part. In Canada, 33 + 36 don't equal 66 :) ).
    Was just being lazy and wanted to stay with single caps.
    But I do need to do this right...
    F1nut Posts: 51,778
    edited January 2009
    Oops, that was suppose to be a 30, not a 33. Damn no edit feature.....Justin!!!
  • wingzam
    wingzam Posts: 201
    edited January 2009
    This is the info I was looking for. Don't forget those pictures! BTW,here in America 33+36 equals whatever we want...and we'll add as many zeros as we want to thank you!!
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2009
    Face wrote: »
    I know this does not pertain to the model in this thread, but wanted to correct the above. My SDA-2B's with BLADE/BLADE were perfectly upgraded with the awesome RDO198-1's.
    http://www.polkaudio.com/forums/showthread.php?t=74945
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited January 2009
    Bigerik,
    It looks like the schematics for you 1B crossovers are identical to my SDA SRS 2's that I just restored and the following thread might help.
    http://www.polkaudio.com/forums/showthread.php?t=74946
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited January 2009
    Bigerik wrote: »
    Your large low pass caps are a 130uf and 55 uf (not 85 or 65 as has been published in error). I used a 100+82 Aeon supplied by Sonic Craft in my rebuild. The caps are so large I had to mount them off-board.
    NAD SS rigs w/mods
    GIK panels
  • Bigerik
    Bigerik Posts: 149
    edited January 2009
    55? Are you sure? Thought we had confirmation from Ken at Polk of it being 65...
