I need front speakers!!!
Jigsawpuzzle
I am looking for a used pair of polk speakers i can use as fronts.. I am currently using some old sony speakers that are just ok, but not good enough. I have been considering the TSi 500, 400 or M70, 60, 50
Post edited by Jigsawpuzzle on
What's you budget?
What can i get for 400?
Get some vintage Polk Audio SDA speakers if you have the room. Most are very large.
You can search this site for more info and particular models.
Buy the way, what kind of amp/receiver are you going to be using? -
i have pioneer vsx 1016 7.1 receiver 110 watts per chanel, m10 for surround, cs300 for center
Do you have any rti a5's for sell?
The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Look for them on Ebay - Polk DirectLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Jigsawpuzzle wrote: »i have pioneer vsx 1016 7.1 receiver 110 watts per chanel, m10 for surround, cs300 for center
These specs are from the RTi range, but they are identical in the RT manual (I have both the RT35 and RT55, and have verified this). The 35 are very good, especially for HT. The 55 are fabulous, if you can fit them in, and if you can provide good amplification IMO. My RT55 only woke up when I purchased a NAD receiver. With harman/kardon and Emotiva separates, the RT35 would have been just as good IMO for HT.
http://www.polkaudio.com/homeaudio/specs/rt35i/
http://www.polkaudio.com/homeaudio/specs/rt55i/Alea jacta est! -
The RTi A5s are powerful floorstanders that will move you.
The LSi7 are well-mannered bookshelves that will cultivate your ear.
Either way, both are under $400 from Polk's store, and both are wonderful deals.Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Audio Technica AT-LP120
Mirage CMD-5 x 5
Bic H-100
