Pioneer Elite VSX01 With RTi A9
Dunham_3654
Bi amped with csi a6 center and fxi a6 rears, how do you guys think that will work for power? I really dont want to add an amp right away, to expensive
Panasonic TH50PZ85U
Omnimount Lowprofile Tilt
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
(FXi A6s and CSI A6 coming soon, trying to figure out the sub)
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
Post edited by Dunham_3654 on
No need for bi amping with the 01. It has plenty of power to power your Rtia series polks. No need to add power amps.
Enjoy the excellent receiver.
DanDan
Them 9's will benefit more from a external amp. Doesn't have to be a real expensive amp to get the job done. $200 would be a nice start. Very cheap price for the performance gain.
The RTiA series seem to like power,with the A9 the more the better:cool:Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Yeah a guy I work with spend like 2 grand on his nada amp, I think thats pretty insane, I can get the reciver for $550 bucks, what would you recommend for a $200 amp? A link would be cool. And if I have the reciver why not bi amp it? any negitives to doing so?Panasonic TH50PZ85U
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
(FXi A6s and CSI A6 coming soon, trying to figure out the sub) -
If your primary concern is for HT the Elite should work fine with the A9's but if music is more the concern then an external for the A9's will really make them come alive. No negatives bi-amping with the Elite but i would be suprised to see any tangible gain. That said, why not try it and see if you like itSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Dunham_3654 wrote: »Yeah a guy I work with spend like 2 grand on his nada amp, I think thats pretty insane, I can get the reciver for $550 bucks, what would you recommend for a $200 amp? A link would be cool. And if I have the reciver why not bi amp it? any negitives to doing so?
A used Adcom 545($200) or Adcom555 ($300). The good thing about both of these amps are when your ready to upgrade you can sell them for the same price you paid or even more.
Also You might want to look into a 5 channel amp to run your whole rig which can be had for about $400 starting off. -
I went to purchase the elite reciver and the only thing that questioned me was how cheap it looked :(I dont think its even metal it looked like all plastic, No im thinking onkyo 806... :mad:Panasonic TH50PZ85U
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
