Problem with Monitor 70 crossovers
Dimehead
Hello everyone, I got a little problem and hopefully I can get some insight to what may have happened. My friend has the Monitor 70's for his front speakers and he blew the tweeters out of both of them at the same time. He purchased 2 new tweeters from Polk and when we hooked them up they were barely working and all of the woofers sounded like they were being choked. They all sounded really thin and distorted. I hooked the new tweeters up to my rti12's and they sounded great like they are supposed to. So could both of the crossovers have gone bad in the monitor 70's at the same time like the tweeters did or is it something else?
Front Stage
Polk Audio MM6501 Door's
Polk Audio MM5251 Kick Panels
Back: Polk Audio MM651
Sub : 2x Polk Audio MM1240dvc
Front's : Soundstream Reference 700s
Back : Polk Audio PA D200.2
SUB : Soundstream Referencre 1000s 1ohm
Alpine 3331 EQ
Alpine cda-9856 Receiver
Alpine 3331 EQ
Post edited by Dimehead on
Yes. If the speakers were being pushed that hard the tweeters were both blown there's a good chance the crossover sustained damage too. Remove the crossover (pull out all the front drivers, unplug the wires, then unscrew the input cup on the back), look at the circuit board and if anything looks burnt, melted, cracked, charred etc the x'over is damaged too.-Eric
-Polk Audio
