Sealed vs Ported subs
Brian217
Brian217 Posts: 35
edited January 2009 in Speakers
whats the difference? whats better for HT? Thanks!
Post edited by Brian217 on
  • ShinAce
    ShinAce Posts: 1,194
    edited December 2008
    Ported uses energy better, but can sound sloppy, especially if the box is too small.
    Sealed tends to sound more accurate, but is not as loud, and can still be sloppy if not using the right sized box.
    The biggest difference is heard when you listen to potential options.
  • apphd
    apphd Posts: 1,514
    A lot of thoughts on this topic in this recent thread http://www.polkaudio.com/forums/showthread.php?t=76014
  • leroyjr1
    leroyjr1 Posts: 8,785
    I like my sealed Micropro 4000 but ............... it's not as loud as I like. I personally like the slam and volume of good ported sub without the port noise.
    I think a good sealed sub will do good at both music and HT.
  • Olivier
    Olivier Posts: 2
    Also, unless i'm mistaken a sealed sub will react faster than a ported one, making it better for faster bass.
    Listening to both type is the best way of knowing which one you prefer, both usually, for big, deep bass (hip-hop, raggae,...) I think a ported sub does a bit better job. For rock, a sealed one might be a bit better... but then it's a question of taste i guess.
  • Conradicles
    Conradicles Posts: 6,335
    IMHO a sub with a passive radiator sounds better than both sealed and ported!
  • Conradicles
    Kex wrote: »
    Are you thinking musical priority?
    Both musical and HT.:D
  • Conradicles
    ShinAce wrote: »
    Sloppy is a perfect word for most ported boxes.
    In a car system, ported is great.
    But for HT, go with sealed or a box with a passive radiator.;)
  • curved
    curved Posts: 664
    Any large sub IMO must be sealed and use a powerful amp. I think they tend to sound a little sloppy, loud and great for HT, but a little sloppy for 2-channel listening.
    Ported subs can be great if the R&D went into it (box size, box structure, port size, port depth, etc).
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • wingnut4772
    wingnut4772 Posts: 7,519
    I went from ported to sealed and what I lost in SPL I gained in depth, speed and accuracy. I just doubled up on the boxes and the HT is slammin'.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • SlowcarIX
    SlowcarIX Posts: 887
    i got the same sub as wingnut4772 - sealed subs will allow you to play into the ultra low frequency in many of todays lossless movie soundtracks. this is the f-irene scene in black hawk down, 5Hz cone excursions. a ported will encounter overexcursion w/o a hi-pass filter
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • Brian217
    Brian217 Posts: 35
    Thanks for your help!
  • Eric W
    Eric W Posts: 556
    leroyjr1 wrote: »
    That's not a sealed sub- it's vented via passive radiator. Add another one if you want more volume :)
    On a seperate note there's far too many generalizations in this thread. Each design has its positives and negatives. Like everything else in audio, it's a tradeoff. There are sealed subs that sound sloppy and ported subs that sound tight. It depends on a combination of things, such as the driver design, suspension, materials, cabinet, tuning etc.
    -Eric
    -Polk Audio
  • bopicasso
    bopicasso Posts: 878
    Slowcar,
    Love your setup... It made me go to HSU Research webpage and check them out.. Wish I had the extra cash, and the HT room to put it all in lol.
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • SlowcarIX
    edited January 2009
    bopicasso wrote: »
    Slowcar,
    thank you :D
    my 7.(1x4) HT setup
    Buttkicker
  • shenlonco
    shenlonco Posts: 42
    edited January 2009
    A seald box always sounds better even in speakers...as you will notice most high end speakers use sealed inclosures.. I think of it as this way a seald system shows it's true sound that it produces and a ported system is artifical kind of like man made not natural due to ports and dementions of them in the cabinet to get the most base out of a box in a small size...and what you here to me is sloppy not as tight bass it sounds destorted this is why speaker makers that have ports always explain how there port does this and does that stopping turbulance and resenance and so forth.
  • Eric W
    Eric W Posts: 556
    edited January 2009
    shenlonco wrote: »
    Not quite. High end speakers use ported enclosures too. B&W 800 Series, even Wilson Audio speakers- the most expensive speakers on the market.
    -Eric
    -Polk Audio
  • manman
    manman Posts: 256
    edited January 2009
    Keiko wrote: »
    X4 :D
    You're Wife must be more forgiving than mine bro. :rolleyes:
    One measley little sub and I'm always being told, "Turn it down Michael"
    This is why I left the nest when I was 17 dammit! :p
    I hear that... when I was younger I just wanted to make enough money to buy all the electronics I love. After I got married that goal turned into making enough money to get a house big enough to have my own seperate room to put them in so I don't get nagged about them anymore!
  • george daniel
    george daniel Posts: 12,096
    edited January 2009
    yep,,, three words that just rain on the parade,,"turn it down"
  • Motzart
    Motzart Posts: 1,075
    edited January 2009
    It's nice having my own house now!
    You don't have a neighbor in a joining apt bang'in on the floor or the ceiling.
    Guess they just don't appreciate below 30hz! :D
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
