First "Real" Home Theatre
sigma
sigma Posts: 8
edited January 2009 in Speakers
Hi, I'm in the process of accessing various components for a HT, and I was dumbfounded in choosing the right set of 5.1 set from Polk Audio. I have narrowed it down to these two sets (Main, Center, Surround, Subwoofer):
RTi 10
CSi 5
FXi 5/RTi 6/RTi 4
PSW 505
Or the:
RTi A7
CSi A6
FXi A6/RTi A3/RTi A1
PSW125
Firstly, I am a bit confused about my surround options. The bipole/dipole surrounds versus the standard bookshelf speakers; what are the main advantages/disadvantages that each possess? I have a medium sized room and it is an open concept connecting to the kitchen. Would that environment change any objective views on the sets or the selection of surround/bookshelf speakers? Which surround option compliments the front and center speakers the best?
Which of these sets provide the better overall sound? Are the newer models significantly (or even slightly) better than the older ones. If price wasn't an issue which set would be the better buy? Which would you buy? :)
I believe in getting things right the first time, so I want to make a very informed decision that will last me with good quality for a while.
Thanks for your time and all your help and input!
BTW: I plan on using the Harman Kardon AVR-354 (with the latest firmware). Is this receiver adequate to power this system? Is there any alternatives in the same range that I should consider (especially from Pioneer, Denon, Yamaha, reason being I have a couple of gift cards from a dealer that carries mostly these brands...haha)?
Post edited by sigma on
  • cfrizz
    cfrizz Posts: 13,415
    edited December 2008
    Welcome Sigma. I would go with option 2 with the FXi A6 and switch out the PSW sub for a DSW sub which is far superior the the PSW series.
    Make sure that HK has preouts so that if you choose you can add a separate amp later on down the line when your wallet recovers.
  • sigma
    sigma Posts: 8
    Thanks cfrizz!
    In what way would the FXi A6 best the bookshelves? Also, what advantages would the DSW bring to the table?
    The HK has preamps.
  • curved
    curved Posts: 664
    Option #2. I like the looks of the A series - no silver fronts, feet, etc
    He is saying the sub is hands down the weakest link out of everything mentioned. I would get a better sub or wait until you have the money to buy a better sub.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • dorokusai
    dorokusai Posts: 25,576
    Curved - cfrizz is a female.
    Sigma - I like both suggestions mentioned by those two people....whoever they are. The DSW series is overall a much better performer than the entry level PSW series. It hits harder, lower and with more confidence. It's worth the money and to boot, the PSW505 has been discontinued for some time.
    Surrounds?...the FXi offers a better, open and diffuse surround experience and is best suited for movies. You could buy either and properly set them up...and wake up in your own excrement. I suggest the FX series since it's purpose was specifically surround sound. Good luck.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I'd have to agree with everyone else.
    Go with the RTi A7 fronts, CSi A6 center, FXi surrounds and you should be very satisfied with your sound. Like everyone else said though, I'd go with a better sub. The DSW series subs are great...the PSW subs aren't really the most highly regarded though.
    The AVR you mentioned should do a fine job powering them, though you may eventually want to look into an external amp for at least the A7's. Those are power hungry speakers, and open up a lot more when you put the juice to them a bit harder.
    Let us know how it works out for ya though, and welcome to Club Polk
    Curt
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Kchill
    Kchill Posts: 262
    Welcome to club polk. I would agree with the rest of the folks here. The rtia line is very nice but if you come across a great deal on th rti 10 grab them!! Also check out polks own ebay site as they have about 15 sets of fxi3's forabout 150.00. They are white. I did a project back in the spring when I got mine and painted them black. Please note that the fxia's only come in black and white not cherry if you were interested in the cherry rtia's. I have come to learn that my Rti10's do need power. In fact I am disapointed in my receiver not being able to push them. Don't think for a second that the receiver will habdle those 7's or 10's. I like emotive for an external amp and will look into it when I complete my basement. Get a reciever with preouts. What you may be concerned with next is will the reciever be update proof. So I would get a reciever that does all the latest audio such as true dolby and hd dts. This should put you under 500 for the reciever the amp may cost you about the same if you look in the right places. As faw as the sub many people have looked outside of polk for that. But I would suggest that you get the mains first with the amp and see how the bass sounds. It might surprise you. Have fun with it because people here seems to never stop upgrading :-)
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
  • sigma
    sigma Posts: 8
    Thanks guys for all the input!
    Option two seems to be the winner by consensus, and I will probably stick with the FXi A6 for surrounds and the DSW sub. Hopefully I can get a package deal and save some money for an amp, but that's another thread...haha.
    BTW: Is there any authorized Polk dealer online (besides Polk's website and eBay) that ships to Canada (or has physical stores in Canada)? I know Future Shop has some of the RTi line but they lack the DSW Sub and FXi A6 in black.
    Thanks again for your time and input!
  • Menasor
    Menasor Posts: 283
    I say depends on price. If you can get both for the same price, go with the RTi A line. Otherwise, if you can get setup #1 for 2/3 the price of #2, I'd go with #1.
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
  • Sherardp
    Sherardp Posts: 8,038
    Does the budget allow for a SVS sub, PB13 Ultra would be killer in this setup.
    http://www.svsound.com/products-sub-box-pb13ultra.cfm
  • sigma
    sigma Posts: 8
    edited January 2009
    Unfortunately the SVS Sub is way out of budget...hehe
    The NAD units are really nice in specification and seems to have a nice build quality. I'll have to look into them just for fun.
    Unfortunately I've hit a road block, the dealer I'm buying from says they are not going to carry the FXi A6 or the DSW series from Polk until further notice (the main reason is that they are a "big box" retailer that has a more lower end customer base). However, the dealer says that they can add the RTi A3/A1 or FXi A4 paired with a PSW 125. Would I compromise a lot downgrading to these speakers (paired with the RTi A7/CSi A6)? The only thing keeping me from walking away is that I have a whole lot of gift cards and a nice package deal waiting for me...
  • Levrah
    Levrah Posts: 9
    edited January 2009
    Save oodles of green and go for option #1. The differences between the RTi/RTiA are essentially cosmetic. Drivers/crossovers appear to be identical. For HT I would also get the RTi8 instead of the 10, especially when using the CSi5. Invest in the FXi5's. Skip the Polk sub. Use extra funds and invest in a Velodyne or HSU.
    The AVR-354 will be more than enough for that system.
  • NewHTguy
    NewHTguy Posts: 584
    edited January 2009
    Levrah wrote: »
    Why would the Csi5 match the Rti8's better than the Rti10's? Just curious because I love my CSi5 and Rti10 combination. They blend perfectly.
    Btw, Audio Advisor has some nice deals on Velo subs. Check out the clearance gear.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • Levrah
    Levrah Posts: 9
    edited January 2009
    just a matter of preference. Plus 8's and a higher quality sub make more sense (to me) given the amplification available.
  • comfortablycurt
    edited January 2009
    Levrah wrote: »
    How would the CSi5 work better with the RTi8's? That's the biggest center channel in the RTi series. It will work just fine with the RTi10's.
    The differences are mainly cosmetic between the RTi/RTi A series, but the sound quality of the A's is better. It isn't a night and day difference by any means...but the curved shape of the RTi A's cabinets does help with acoustic resonance, and makes a definite difference in SQ IMO. If money allows, I say go with the RTi A's. If you're working on a tighter budget, the RTi's may be the way to go. You'd still be more than satisfied with either choice.
  • Levrah
    Levrah Posts: 9
    edited January 2009
    once again... just a matter of preference.
