Virus taken over...
MrNightly
MrNightly Posts: 3,370
edited January 2009 in The Clubhouse
Ok, I have some sort of trojan/virus on my desktop computer. It's a deep one too. I can't right click anything on my desktop, and it locks everything up every few minutes.
It won't let me run any spyware removal programs, and window's defenders just get locked up trying to locate it.
I can get online, but that is about it. Everything is running extremely slowly. It's killing me.
I think it's lodged itself into the memory, because when i run everything on diagnostic setup, it still won't let me install a new anti virus program. i put one on disk (locks up if i even google/yahoo anti virus software) and tried to open it but it gives me some sort of error.
Anybody have any idea how to conquer this thing?
Now my window's is yelling at me every 20 seconds with this error, "Windows - no disk - Exception processing message C0000013 parameters 75b6bf9c 4 75b6bfc9c 75b6bf9c" Cancel ,try again, continue. Doesn't matter what I click, it just pops back up.
I was going to buy a good anti virus cleaner, but what's the use if I can't get it to boot up anyways from the D drive?
I was told to start everything in safe mood, and try to install it that way, but it just locks up still.
Weird. Any help out there? I typically run Spybot Search and Destroy along with Avast and AVG. I tried all of them to no avail. :(
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub :D:D:D
Denon 3805
Rotel RB-985 5-Channel Amplifier
Post edited by MrNightly on
  • dorokusai
    dorokusai Posts: 25,577
    edited December 2008
    Backup what you can't live without and re-image the whole drive.
  • MrNightly
    dorokusai wrote: »
    How do you do that? :) And will that help if the bug is in the memory?
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • Phasearray
    Phasearray Posts: 437
    Receiver - Onkyo HT-R340
    Front - Pioneer S-HF21
    Center -Onkyo SKC-340C
    Surround Back - Polk R15 <--Ticket to club polk
    Subwoofer - Onkyo SKW-340
  • WilliamM2
    WilliamM2 Posts: 4,781
    It's probably malware or spyware. I've had good luck cleaning up other's PC's with this:
    http://www.malwarebytes.org/
    If you can't complete a scan, try booting into safe mode and scan from there.
  • Phasearray
    My computer has only been hijack like that once. What I use to do is install windows on a 2nd hard drive and use the new operating system to scan the old hard drive.
  • lightman1
    lightman1 Posts: 10,794
    ...shoot it...then set fire to it....
  • obieone
    obieone Posts: 5,077
    lightman1 wrote: »
    I almost did! PC's= EVIL:mad::eek:
  • dudeinaroom
    dudeinaroom Posts: 3,609
    start up in safe mode. click start, click run. type in msconfig.exe hit enter. Click on the tab that says services. click on the check box that says "hide all Microsoft services. uncheck every thing that does not have the name of programs,or devices that you use. Next click on the tab that says startuo, uncheck every thing. click apply, ok, then reboot. after restart run antivirus
  • Erik Tracy
    Erik Tracy Posts: 4,673
    I had something like that happen to me recently.
    Computer was very slow and even surfing to familiar sites like the polk forum did not always complete loading - sites would stall and not finish, or I'd get site not found errors.
    I actually used a recommendation from Consumer Reports for a free antivirus program from avira.com for personal use.
    It found 4 trojan viruses and I'm as right as rain - as the saying goes.
    I thought my previous free anti-virus was ok, but I guess not.
    I'm not advocating avira.com - just my personal experience with it - but the point is you need a good anti-virus/spyware/malware suite.
    Good luck cleaning up - it is a nuisance.
  • WilliamM2
    Why not just scan in safe mode? I have never seen malware, spyware, or virus that showed up on the startup menu.
  • mantis
    mantis Posts: 17,201
    Keiko wrote: »
    My advice...Replace it with a Mac.
    I gotta say listen to Keiko, he is a wise man.
    Dan
    Dan
  • Fireman32
    Fireman32 Posts: 4,845
    WilliamM2 wrote: »
    +1 I have cleaned up quite a few computers with this.
  • obieone
    Malwarebytes ROCKS!!! I just spent 3 days wrestling with my system, and it found SOMETHING in the registry, that AVG couldn't find. So far, so good.
  • SKsolutions
    SKsolutions Posts: 1,820
    It may not be viral. "it'' may be looking for something. . . usb, raid, stick etc.
    Try:
    Stop QT from loading at startup using msconfig, and then uninstall quicktime.
    Also: try killing dit.exe,
    -Ignorance is strength -
  • Sami
    Sami Posts: 4,634
    UBCD4Win works wonders if you have a NTFS disc you need to clean. If other then I would recommend one of the Linux LiveCD's (Knoppix, Ubuntu etc).
  • Rivrrat
    Rivrrat Posts: 2,101
    WilliamM2 wrote: »
    I just downloaded this and ran it. It picked up stuff nothing else I have found.
    My equipment sig felt inadequate and deleted itself.
  • ohskigod
    ohskigod Posts: 6,502
    Keiko wrote: »
    ding ding ding........winnah!!!!!!!!!
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • Sami
    Sami Posts: 4,634
    ohskigod wrote: »
    Blah, overpriced and way too hyped. You want to go the open source based OS route, Linux is a much better choice.
  • MrNightly
    Unfortunately, nothing is working guys. This really sucks.
    I can't install anything on my computer either in safe mood or not. MSConfig doesn't help either, no matter how many ways I try to boot the stupid thing. I think it's majorly fubared!
    Pity. I don't have it in the budget to buy another computer either, as I just picked up the PS3 instead :)
    Any other idea's fellas? Can you remove memory from the computer and try booting then? Ha.
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • Sami
    Sami Posts: 4,634
    Can you burn an ISO to CD? Are you posting from that PC?
  • John30_30
    John30_30 Posts: 1,024
    There's a bootable disk we used to use to disinfect P.C.'s called BARTPE. You have to have a bit of skill in order to build the bootable windows disk with the anti-malware apps in the image. Well, just enough skill to follow instructions.
    It's a Live CD which allows you to work on the infected drive without booting into that drive. You run antivirus, trojan killers, etc. all of which you've built into the CD. They recommend Win Server2003, but I'm pretty sure we used XP Pro.
    Google it, then go to the plugins page and get as many of those as you think you'll need. It'll take some time, but you'll always have that disk plus the experience.
    Obviously, you have to do this from a clean install. Borrow a friend's computer if you only have the 1.
    Or do as someone suggested and install a fresh version on a different partition, then work from there.....
  • WilliamM2
    MrNightly wrote: »
    Didn't the PC come with a restore CD, or the OS on CD or DVD? It should have.
    No reason to replace the whole computer.
  • Sami
    Sami Posts: 4,634
    John30_30 wrote: »
    I would use UBCD4Win myself (based on BartPE), but you do need to have a copy of XP to build it. Does not require much of a skill set, very easy to use.
  • MrNightly
    Sami wrote: »
    I don't know what an ISO means! No I am posting from my phone. I do have another computer in the house, older but it still works great! I will have to try to make a boot disk.
    Also how do you just wipe everything clean on a computer and start over? Re install the Os?
    Thanks!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • John30_30
    MrNightly wrote: »
    Thanks!
    ISO just means image. It's a standard image format.
    "What's that mean?"
    An image of a bootable O.S.,etc will contain hundreds or thousands of files all as a single file, or image or ISO, which the burning app translates back to those hundreds of files. It's a sort of exact duplication format is the reason.
    treitz3 Posts: 19,195
    I just ran across this on another forum I hang on. I have no idea whether this is what happened to you but I figured I'd post it anyway. Anyhoo, here's the post....
    Read and heed!
    Subject: URGENT, URGENT, URGENT!
    TWO SUBJECT LINES TO BEWARE OF:
    Just verified this with Snopes and it is REAL. ALSO WENT TO TRUTH OR FICTION, IT'S on their site also.
    PLEASE INFORM EVERYONE you know!
    Emails with pictures of Osama Bin-Laden hanged are being sent and the moment that you open these emails your computer will crash and you will not be able to fix it!
    1.) If you get an e-mail along the lines of 'Osama Bin Laden Captured' or 'Osama Hanged', don't open the Attachment!
    This e-mail is being distributed through countries around the globe, but mainly in the U.S. and Israel. Be considerate & send this warning to whomever you know.
    PLEASE FORWARD THIS WARNING AMONG FRIENDS, FAMILY AND CONTACTS:
    2.) You should be alert during the next few days: Do not open any message with an attached file called 'Invitation' regardless of who sent it. It is a virus that opens an Olympic Torch which 'burns' the whole hard disc C of your computer! This virus will be received from someone who has your e-mail address in his/her contact list, that is why you should send this E-Mail to all your contacts. It is better to receive this message 25 times than to receive the virus and open it.
    If you receive e-mail called 'invitation', though sent by a friend. Do not open it! Shut down your computer immediately! This is the worst virus announced by CNN, it has been classified by Microsoft as the most destructive virus ever. This virus was discovered by McAfee yesterday, and there is no repair yet for this kind of virus.
    This virus simply destroys the Zero Sector of the Hard Disc, where the vital information is kept.
  • Sami
    Sami Posts: 4,634
    MrNightly wrote: »
    Like John said, it's an image. If you don't have XP disc to make UBCD4Win, I might be able to help to get one, otherwise just make a bootable UBCD4Win disc and run virus and malware scans from it. It's easy and should do the trick, no need to format the drive.
  • MrNightly
    Sami wrote: »
    OK. I made a UBCD4Win and have it on a disc. I will try to use it for my computer now. Do i need to put the malware program on the disc to scan from it?
    Also as a side note, I tried to re instll my OS with the disc from Dell. I put the disc in, booted the computer, and booted from the disc. It ran through a bunch of files and then flashed with this error: "STOP: c0000221 Unknown Hard Error / systemroot/system32/ntdll.dll"
    I have no idea what that means, but it made me abort my re installation.
    Anyways, I am on my laptop to make the bootable disc. Tell me if there is anything else I need to know before I start booting up :)
    Virus' watch out... here I come. Armed and Dangerous. Ha
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • tcrossma
    tcrossma Posts: 1,301
    Sounds to me like you might possibly have a physical hardware problem -- hard drive or RAM issue maybe.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Sami
    Sami Posts: 4,634
    tcrossma wrote: »
    Likely. Boot from UBCD4Win, it will give a lot of tools to diagnose the problem (antivirus etc are included standard). If that boot disc causes crashes as well, it's definitely hardware issue.
    memtest86 is a must program to run (there should be an option from UBCD4Win to run it instead of booting into Windows), if not then burn a copy of UBCD or memtest86 itself.
