Turntable issue?
joeparaski
joeparaski Posts: 1,865
edited December 2008 in Troubleshooting
I have a Technics SL1100 with an Ortofon cartridge. The sound is not "steady"...meaning that it seems to go up and down slightly and "clear/not clear" for lack of a better term.
Is this a sign of the cartridge starting to go? Or is there some other issue with the TT?
I've isolated the problem to the turntable because this happens when it's plugged into either the 2-channel system or the multi-channel system.
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • joeparaski
    Ok, let me bump this to the top and "hopefully" I'll get a couple of answers by the time I get back from work today. Have a great day folks...yes, it sucks to work on Sunday.
    Joe
  • fbm211
    fbm211 Posts: 1,488
    I would guess it may be the catridge.Can you get a spare one or borrow one to check?Or try to find one on audiogon for cheap?Try to find a place with a money back return policy that way if yours is bad you can return it and get a better one.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • joeparaski
    Thanks, I'll try changing the cartridge...I know I have another one around somewhere. I'll report back if it changes anything.
    Joe
  • hearingimpared
    hearingimpared Posts: 21,136
    Joe it sounds to me like a clear case of the cartridge getting (gotten) old. If the cartridge has a removable stlyus, I would try that first. If the cartridge is not that expensive and you can afford it right now go for a better cartridge rather than changing out the stylus. However, before you do anything, break and make the cartridge wire connections and try it. If that doesn't work, try my suggestions above.
    Merry Christmas my friend.
  • joeparaski
    I thought I had some extra carts and I did. I replaced it with a Shure M97xe and the problem went away. Thanks for the suggestions.
    Joe
