liberty speaker wire question
hioutput_ht
hioutput_ht Posts: 3
I'm about to start installing my inwall 7.1 system and had a question about which speaker wires would best suit my setup. I will be using the tc series speakers all around, with the longest run of wires being 30 feet. I was looking at the 12awg 2 conductor liberty thx cert. cl3 wires. Is 12 awg overkill? Will i hear a difference over 14awg ? And can it hurt in anyway by using too thick a wire?
thanks in advance
Post edited by hioutput_ht on
  • WilliamM2
    WilliamM2 Posts: 4,810
    edited December 2008
    14ga is more than enough for a 30 foot run. Using 12ga won't hurt a thing, but it can be more difficult to pull through the walls, no big deal though.
    But if I were you, I would skip the THX certified wire, all it does is add extra expense. What could THX possibly certify the wire for? The fact that it conducts? Kinda silly.
  • dorokusai
    dorokusai Posts: 25,625
    I'd save a couple bucks and pick up the CL3 Belden 12 awg.
  • ben62670
    ben62670 Posts: 15,969
    dorokusai wrote: »
    Yep. or the Audio Quest in wall stuff.
    Merry Christmas
    Ben
    Ben
  • hioutput_ht
    after doing some more research with all of your recommendations i will be going with the 14 gauge audiquest. i did exact measurements today and im actually going to be running two 40 foot runs. Does this still fall within 14 gauge specs or should i bump it up to 12awg?
  • inspiredsports
    inspiredsports Posts: 5,502
    14 gauge audiquest . . . 40 foot runs. . . does this still fall within 14 gauge specss?
    Handy chart here . . .
    http://www.roger-russell.com/wire/wire.htm#wiretable
    . . . the rather lengthy article is also an interesting read.
    Happy Holidays!
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • mantis
    mantis Posts: 17,629
    14-2 Liberty is all you need.
    Dan
    Dan
