CSi5 only tweeters are working
dhead1
dhead1 Posts: 6
edited December 2008 in Troubleshooting
After re arranging my surround system, I am getting sound only thru the tweeters on my center channel CSi5. The speaker was not jarred or dropped and the connections look to be tight. I have no problem with the processor or the amp and am sure it is the CSi5. What do you think the problem is? What could of happened, I actually never even moved the speaker itself, I just disconnected the wires and then reattached them a day later. I still have 1 year on the warranty, I purchased it at a local circuit city, and registered the speaker on line here. What is the procedure for a repair?
Thanks,
Duane
MyHT:
Fronts:RTi12's
Center: Csi5
Surrounds:
FXi5's
Sub: PSW505
HDTV: Toshiba 56"
Processer: B&K Ref 50
Amp: Rotel RMB-1095
POWER CONSOLE: Pure AV-AP21300-12
Post edited by dhead1 on
  • Jed Leland
    Jed Leland Posts: 183
    Hello,
    Is it possible the binding post jumper plates have come loose? If so and you've made your connections to the upper binding posts only the tweeter will play.
    Jed
  • thsmith
    thsmith Posts: 6,082
    Since you disconnected the wires and re-attached I would triple check connections.
    May have a second pair of eyes examine.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Jed Leland wrote: »
    Hello,
    Jed
    That would be my guess.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • dhead1
    dhead1 Posts: 6
    You are all correct. I checked and rechecked before I originally posted. But a bit of fiddling did the trick.
    Thanks for the help.
    Duane
    MyHT:
    Fronts:RTi12's
    Center: Csi5
    Surrounds:
    FXi5's
    Sub: PSW505
    HDTV: Toshiba 56"
    Amp: Rotel RMB-1095
