CSi3 Minor Problem
TheMARPATNinja7
I recently bought a CSi3 and I noticed that for some dialouge in certain movies it gets a little crackly. Everything else sounds fine on this speaker and I do not notice any crackle for my video games or music. Im running 100w to this speaker with 14 gauge sw so there shouldnt be any obvious problems. Could it be my DVD player, reciever, Coax digital connection, or something with the speaker? I really have no idea on this one, any ideas?
Post edited by TheMARPATNinja7 on
Hello,
Thanks for posting on the Forum. The best way to determine if the problem is with the speaker or not is to connect the CSi3 to either the right or left front speaker connections. Then connect the previous right or left speaker to the center speaker connections. Then see if the sames sounds can be heard at the same place in the program material.
Regards, Ken -
Thanks a lot Ken, I just did this and there was static on all the speakers I tried. (Really glad theres no problem with my Csi3!!!) I'm going to assume it is my DVD player and not my reciever because I only notice this with DVDs, hopefully I'll be getting a Blu-Ray player soon enough so I won't have to worry about it. Thanks again for the help!!!
