RTIA5 Best frequency Settings?
andrew_mac
What frequency should I set my RTI a5's to, or should I set them to large?
I played around with this a lot but I can't make up my mind what I like best. I just want to know what some of you guys/gals are running them at? Thanks.
Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's
Surround - RtiA1's
Center - CsiA6
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's
Post edited by andrew_mac on
andrew_mac wrote: »What frequency should I set my RTI a5's to, or should I set them to large?
Some receivers allow you to memorize different settings, so you may be able to have one setting with LARGE for music and no crossover (for example) and a different memorized setting with SMALL for HT and your chosen crossover point (for more punchy LFE).Alea jacta est! -
Yeah, I think your right, Large does sound best with music. I notice the vocals clean up a little when I set them to 80hz but they are really forward sounding speakers anyway so I think Large might actually complement them by taming the brightness down a bit. Does that make sense?
I've been running the sub at 80hz while the fronts are set to Large. This seems to blend well for music. Not sure about HT yet.Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's
