Recommendation for 52" LCD mount
mrbigbluelight
mrbigbluelight Posts: 9,878
edited December 2008 in Electronics
Well, we've been looking at mounting our 52" LCD on the wall lately, and was hoping that somebody would have a good source for a mount (tiltable) that is REASONABLE.
Stopped by the local "Going out of Business" CC over the weekend, and ..... geeez Louise ....... "Clearance" for $525 ?!?
Thanks for any input, if we get the TV up on the wall, we can get the CS2 relocated and life will be good !
Post edited by mrbigbluelight on
    billbillw Posts: 7,792
    I have been quite happy with the one I purchased from Monoprice.
    http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10828
    Any of the ones in the "Tilting Type" section. I think they are all basically the same except for width/color. There is one called a "premium" that is supposed to have thicker steel, but I found my normal one to be sufficient for my 85 lb plasma TV.
    I specifically used #2852, but pick whichever one suits you.
  • mrbigbluelight
    Checked out Monoprice, and they have some real nice prices ! Thanks for that heads up.
  • mantis
    mantis Posts: 17,559
    I prefer the Omnimount models. U3 tilt is what I use in my master bed.It's also my mount of choice on the job. I feel very safe with these mounts as they are made very well.
    Dan
  • brettw22
    brettw22 Posts: 7,623
    Go to Costco and check out their setup. I saw one the other day that had a lock pin adjustable angle tilt bracket and it was under $100. I can't think of the brand, and I looked on their site but didn't see it.....if I was putting the 52" I just bought on the wall I would have grabbed it. It doesn't have any sort of swiveling, but you're not looking for that, right?
  • tryrrthg
    tryrrthg Posts: 1,896
    +100 on the monoprice mounts. I bought one last year. Very solid, and the price can't be beat!
  • mrbigbluelight
    Thanks for the inputs; I should have thought of Costco, too. I wound up getting a "Planet 3" tilting (didn't need it to rotate at all) flat panel wall mount from Fry's. It came today, took it out of the box, and am real pleased with the metal construction. Doesn't look like cheap import pot metal and it is supposed to support up to 165 pounds.
    Mounting hardware is good, although I'm anchoring this booger down to withstand Force 5 hurricanes.
    Next on the agenda is to figure how high to mount the TV, and what angle to tilt it for the best view. I need to factor in viewing from a normal seated human being position, and viewing like a beached whale plopped out prone on the couch. :o
  • higgins79
    higgins79 Posts: 72
    I have always been partial to omnimounts. They are built rock solid, a bit pricy but real solid.
    TV ................Sony kdl52xbr4
    Reciever ........Denon AVR 988
    Amp -............Monster MPA 2250
    Bluray............Sony PS3 (80gig)
    Hddvd............xbox 360 Hddvd
    Power centers.Monster 3600II & 2600II & 1600 x2
    Voltage..........Monster AVS 2000
    Fronts ...........polk Rti12s
    Center ..........polk Csi5
    Rears.............polk Fxi5s
    Sub ..............Infinity PS12
    cables............Monster / DIY
    Video games...XBOX 360 / Wii
  • Pepi28
    Pepi28 Posts: 248
    The center bottom of my plasma is mounted at eye level maybe a bit lower and works great for me that way if that helps you out any. Also I sit about 13' away from it so I really dont have any issues with it not being centered at eye level, it's basically still dead ahead for me.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
