sub auto on/off noise
drballard33
I tried searching and couldnt find a specific answer for this. I have a sub connected that has the auto on/off feature when it senses a low frequency, anyways, when it turns on there is a pop noise. I thought it was the surge of power going to it so I hooked it up to a power conditioner but still no luck. I have it hooked up using a single RCA cable to a Y splitting it into the two red and white cables. Any help would be appreciated.
Sony STR-DG920 7.1 receiver
Sony 52" 120hz Bravia LCD
Sony SD350 Blu Ray
Polk surrounds and sub
Sony Blu Ray
DirecTV
Sony SD350 Blu Ray
Sony Blu Ray
DirecTV
Post edited by drballard33 on
Try to hook it up without the y splitter and if it still makes the noise then you can count that out. then try a new cable if it still does it then make sure you have the sub plugged in the right spot ( i hooked mine in the multichannel hook up by mistake and the sub kept making a pop). i am thinking one of these should fix the problem because i have a friend who bought a cable for his sub and the cable is bad.
Does your sub not have the left and right hook up? or just use the single cable instead of the Y splitter to left and right.Audio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Panasonic:TH-42PX60U 42"Plasma
Power Conditioner:
Monster Power: HTS 3600 MKII Home Theater
Dvd:
Sony: BDP-350
Game Systems
WII
PS3 -
What kind of sub is it? Does it have an LFE input? If it does, I'd switch to that.
I had the same problem with my sub for a while. I had it hooked up the way you do, with a Y-cable. I disconnected the Y-cable and just hooked it up to the R input on the sub, and it fixed the problem. I would imagine if you did that it would fix the problem for you too.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
alright, I found my problem, it was the receiver, or at least I think. My original receiver was about 8 years old, so because Santa didnt bring me what I wanted this year I decicded to upgrade my entire system excluding speakers and the noise went away but I also used a high quality sub cable so that may have helped because I am doing a run of about 30 feet through the floor.Sony STR-DG920 7.1 receiver
Sony SD350 Blu Ray
Sony Blu Ray
DirecTV
