Is there a spec sheet for the RT7?
Igo
Igo Posts: 411
edited December 2008 in Troubleshooting
Howdy
I'm curious. Is there a spec sheet available for the LS6501 (RT7) tweeter? I sure would like to take a look at one. A scanned copy/.pdf file maybe?
Thanks a bunch
...Link to my System Showcase...
"ES - Kind'a simple but I like it"
Sony ES STR-DA4300ES 7.1
Sony ES SACD SCD-C2000ES
Sony 400 Disc CD CDP-CX455
Infinity BU-2 Sub-Woofer
Polk Audio RT800i Towers
Polk Audio CS400i Center
Polk Audio FXiA6 Surrounds
Sennheiser HD 280 Pro Headphones
DH-Labs T-14 Speaker Cables
Panamax Max 500 DBS Line Conditioner
Panasonic TH-50PZ85U 50'-Plasma
Play Station III - BluRay
Logitech Harmony 550 Remote
Logitech diNovo Mini Keyboard
Post edited by Igo on
    F1nut Posts: 50,832
    Nope.
  • Igo
    Igo Posts: 411
    One exists but Polk just doesn't make it available? Is that it?
    F1nut Posts: 50,832
    It's proprietary.
  • Igo
    Igo Posts: 411
    What the heck does that mean?
    Nevermind.
  • Igo
    Igo Posts: 411
    All I have been able to go on is a meter reading on the terminals of 5.9 and 6 ohms respectively. I have to assume, with my limited education and research on the matter that the RT7 speaker, being rated at 89 db spl that a 6 ohm/89 db tweeter replacement is in order. With the cut-outs also being similar, I went with the Vifa D25AG-35 1" Aluminum Dome Tweeter. Since I don't know what the cut-off point or slope is for the RT7 low pass (I'm really surprised I couldn't find this stuff out here with Polk) I also have to pick this tweeter for its relatively low frequency rating of 2000 Hz. I'll let you guys know how it turns out. If all things are equal then my only fear now is that the new tweeters will be a bit tizzy being a metal dome.
    heiney9 Posts: 25,221
    What's the issue and what are you trying to do? Doesn't Polk sell replacement tweeters if your tweeter is dead? Or are you just trying to "re-engineer" a perfectly good speaker?
  • Igo
    Igo Posts: 411
    Polk wants $95 dollars for a $30 substitute tweeter that never came stock in the RT7 in the first place. Seems like my conserns are pretty legit to me.
