PSW650 constant buzz
dmiller613
dmiller613 Posts: 1
edited January 2009 in Troubleshooting
I have PSW650 that just started to constantly buzz fairly loud. I unhooked the RCA cables so that the unit was only plug into the AC line and it still buzzed. I then removed both speakers and hooked them up directly to the stereo, no more buzz. I believe the internal amp has a problem. Does this sound correct? Would it be better to buy a new amp or try and have this one fixed? Where would I send it and what would the ballpark cost to fix/ or buy new?
Thanks Dan
Post edited by dmiller613 on
