RTI 12 help
syu425
syu425 Posts: 1
edited February 2009 in Troubleshooting
Hi, I own two RTi 12 for my home theater but the one on the right side isn't producing any high pitch sound and the speaker sound is not as clear as the one on the left. I thought it might caused by the broken dynamic balance on the right speaker? Any suggestion will help and also where can I buy replacement parts?
Steve
Post edited by syu425 on
  • dorokusai
    dorokusai Posts: 25,577
    edited November 2008
    I would double check your wiring on the speaker and whatever is powering them. If that's ok, swap the wiring between the speakers. If it follows the wiring, it's bigger than the speakers....if not, time to break out a screwdriver.
  • ben62670
    ben62670 Posts: 15,969
    Welcome to Club Polk.
    Ben
    Ben
  • dorokusai
    RTi12 Ben.....seriously?
  • ben62670
    dorokusai wrote: »
    My bad. I was thinking RTA:o
    Ignore my post.
    Ben
  • Montoya
    Montoya Posts: 506
    edited December 2008
    I had a similar problem turned out I pushed in the
    Banana plug to far into the amp and no contact was being made.
  • joelpietersen
    joelpietersen Posts: 1
    Sure, it may be an issue of wiring. Better check that one first. It's usually the problem.
    A verbal contract isn't worth the paper it's written on.
    eq plat
    treitz3 Posts: 19,271
    Steve, most likely it's a connection leading to your speaker. What I would suggest is isolating the issue before you go and order some parts. Are the wires in phase? Are all connections solid? As mentioned before, swap the speakers or the wiring leading to both speakers and nothing else to see if the issue follows the speaker. Make sure that the gold jumper has a good, solid footing. Especially on the speaker in question.
