rt1000p buzzing
tecmo04
tecmo04 Posts: 421
edited January 2009 in Troubleshooting
Hi all,
So i come home yesterday from work and decide its time to play some halo. Fire up all the equipment like normal and buzzzzzzzz. Front left speaker is buzzing. There was a power outage and all my clocks where flashing. I think the amp is fried. It buzzes and pops whether i have the speaker connected or not. Top half works fine.
Long story longer i guess the monster clean power didnt do **** to help.
Any one know if the amp is fried?
Is there a way to turn off the cross over and use the speakers without the amp? I imagine i am loosing a lot of the lows because they are being directed to the power sub.
Thanks!
Post edited by tecmo04 on
  • danger boy
    danger boy Posts: 15,722
    edited November 2008
    the amp in the speaker is fried or your external amp? do the RT1000p's have jumpers on them? if so.. remove the jumper and that will separate the subwoofer from the mid's and tweeter and try it out again.
    sorry that happen. i would be mad too if my surge protector didn't do it's job.. call or write to Monster and say WTF?
    PolkFest 2012, who's going>?
  • tecmo04
    tecmo04 Posts: 421
    External amp is ok. THe right speaker top and bottom work great. Also, the top of the left works fine... I am currently using speaker wire to connect the top and the bottom. I still ahve the top and bottom connected, and the power is turned off for the speaker amp
  • ViperZ
    ViperZ Posts: 2,046
    Contact Polk CS, they should be able to repair that amp easily.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • tecmo04
    tecmo04 Posts: 421
    edited December 2008
    good afternoon all,
    in case anyone was curious i received the replacement unit from monster today. it appears to be new! It only took a month of being deprived of my stereo.
    still waiting on if they will approve the speaker repair cost.
  • danger boy
    tecmo04 wrote: »
    good afternoon all,
    makes you wonder though if their surge protectors do any good or not. :confused:
    Doesn't monster guarantee something like $100,000 stereo gear replacement if their equipment ever kills your gear? I'd be checking into that one.
  • tecmo04
    tecmo04 Posts: 421
    edited January 2009
    on the box it says guaranteed up to 500K. I submitted an email quote from POLK saying it would be 65 dollars to repair the amp. I need to follow up with Monster on the status. Ill let you know how it turns out!
