Psw125 so soft base
mauitang
mauitang Posts: 12
edited November 2008 in Troubleshooting
I just got the psw125, and my receiver is onkyo tx-sr304, i connet from LFE use rca cable to the receiver sub out, and i don't know why the sub is so soft...i already turn sub volume to max, and play iron man from my computer,i can fell it, but not alot, can anybody help me with that???
I wonder is because my receiver not good enough for this sub?
on the receiver i set all the speakers to small and the bass to subwoofer crossover is 80
Post edited by mauitang on
  • curved
    curved Posts: 664
    It's not because your receiver is not good enough.....I would check the RCA - what kind of RCA are you using? Double check the connection in the back of the sub - make sure it's connected properly. Also check the sub gain on your receiver.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    I have the Onkyo TX-SR806 and my PSW125 slams!! Your receiver shouldn't make that much of a difference in this equation since it is a self powered sub?? I may be wrong in my thinking, but that is how I see it. I ran my current setup (see signature) with my old Onkyo HTIB receiver, and it worked just fine. I had mine hooked up with a Rocketfish subwoofer cable and had no problems. My old receiver wasn't much different cosmetically from the one you have, but I think it pushed out somewhere around 120 watts per channel, not sure that would make a difference though, hopefully someone with a little more knowledge can give you a better answer. Or like Leroy said in the other thread, check your settings on your Receiver.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • monstershed
    monstershed Posts: 3
    Hi all, have some panels for sale, they are by ATS Acoustics and are 2x4x2. I have a box of 6 for sale at 150.00 plus shipping, email me at rippy43@yahoo.com
