Please give opinions on which amplifier to buy.
stormbringer3
stormbringer3 Posts: 14
edited November 2008 in Electronics
My HT setup is currently LSI 7's for the front speakers, some late 90'S Infinity speakers for the center and rear channels, and a Velodyne VA-810x sub.These are powered by a Marantz SR 8000.
I am looking to upgrade to a LSIC for the center channel and LSI 7's for the rear channels. Even though the Marantz powers my current setup without any problem I am worried that it will be inadaquate to power 5 4ohm LSIs. Therefore, I am considering adding an amplifier. So far I have three possibilities. They are a NAD T-955 for $799(new, but the discontinued color),
an Emotiva XPA-5 for $699, and an Outlaw Audio 7125 for $999. I am not familiar with these brands though my research shows that all seem to be well liked. My top criteria is quality/reliability. Please give me any opinions about these possibilities and also if there is anything else to consider that I am missing.
Thanks.
Post edited by stormbringer3 on
    heiney9 Posts: 25,504
    Thanks.
    Build quality and reliability is pretty good for either brand. All amps will sound a bit different so.......................based on the info you've given either one would work for you.
    Kex wrote: »
    Welcome stormbringer3! Of those that you mentioned, all will work well, but I would get the NAD myself. It's not the most powerful of the three, but there is something magical about NAD that just seems to work, which I discovered when I bought my current receiver, a NAD T754. Despite having only 70w/ch, it performs much better with my system than an Emotiva LMC-1 & LPA-1 combo did, rated at 125w/ch.
    Others will tell you that "watts are watts", and the more the better, so they would probably advise the Emotiva as the best bargain, but I would still get the NAD and consider it the real bargain. I just love what mine does to my music and HT alike, the extra detail and extra bass response has surprised me, and they are rated for 4 ohm and even 2 ohm loads at 0.03% THD. YMMV!
    All three should be reliable (amplifiers are generally much more reliable than receivers). One thing to consider also: of those you mentioned, only the Outlaw has seven channels.
    He didn't inquire about sound, just quality and reliability. :D
  • cfrizz
    cfrizz Posts: 13,415
    Welcome SB3.
    All of the companies listed make good products you would do fine with any of them.
    However, I am one of those that will tell you to get at least 200wpc especially for the LSI's.
    You won't have to worry about straining the amp & you will know that your speakers are operating closer to their full potential. The more power you feed those babies the better they sound.
    Don't be afraid to buy used from Audiogon as well. Look for Sunfire, Parasound, Adcom, B & K, etc.
  • stormbringer3
    Thanks for the advice! I'm leaning toward the NAD T-955. A new possibility has emerged. There is a new Parasound -5125 on sale for $1199. I know that this is an excellent price, but would the extra $400 on a Parasound over a NAD be $ well spent? I'm also thinking of upgrading my sub and buying the Parasound would use up most of my sub money.
    Thanks again.
  • HHStuart
    HHStuart Posts: 263
    I have front LSi 15's, a center LSi C, and will add rear LSi 7's. I have a Sony STR-DA3400 ES with (theoretically) 100 watt per channel into 8 ohms.
    I am also concerned about the same problem. Do I need an amplifier?
    Perhaps a two channel to handle the LSi 15's - surely the receiver can handle the rest? How much power do I need? Many of the better amps seem awfully expensive. Of those able to handle a high current load and more in my price range are
    Onyko 282 (there is also a 282p) $349 - there was negative remark on this on Amazon (somewhat noisy)
    NAD 272 - ($499) one negative reference but overwhelmingly positive overall
    B & K Reference 125.2 ($648)
    Adcom GFA-5400 ($539) 200 wpc into 4 ohms
    Rotel and Denon are nice but pricey.
    Polk's web site also mentions Yamaha, Harmon_Kardon, and Pioneer Elite.
    Yamaha doesn't seem to have any 2 channel power amps except the MX-D1 at $2600 - just integrated amps or receivers.
    Any comments about these or alternatives would be welcomed.
    Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
    Subwoofer - Epik Legend
    Receiver (as Preamp) - Sony STR-DA3400 ES
    Amplifier - Outlaw 7125
    Television - 58" Samsung Plasma PN58B860
    Blu Ray - OPPO BDP 83
  • ben62670
    ben62670 Posts: 15,969
    Buy used. Those prices are way to high. Look at audiogon.com You will pay about 1/3 new cost. At those prices you can get a real nice powerful used amp. I think there is a nice Rotel 5 channel here in the Flea market.
    Ben
    Edit: BTW did you get initiated yet:D
    treitz3 wrote: »
    No, you must also strip naked and run down your street yelling "Polk Rules!!!" and then take a dump at the end of the road, running back to the house using no toilet paper.
    It's part of the Polk initiation dude. :D
    Ben
  • HHStuart
    HHStuart Posts: 263
    ben62670 wrote: »
    Ben
    I'm a little leery of used equipment. Maybe I'm not adventurous enough.
    I bought my first Polk speakers back in 1987 so maybe I don't need to be initiated. ;)
  • HHStuart
    HHStuart Posts: 263
    Kex wrote: »
    I would not put any LSi speakers on that receiver. Very few receivers will drive 4 ohm speakers. Your best option would be to get a multi-channel amplifier, but you'll have to check first if it has pre-outs (they are frequently close to the pre-out for the subwoofer, and should have one RCA connection appropriately labeled for each speaker - not to be confused with the multi-channel inputs for SACD and DVD-A).
    P.S. Welcome to Club Polk, BTW!
    Thanks for the welcome.
    I would think a receiver that can put out 700 watts per channel (7.1) should be able to handle an LSiC and 2 LSi 7's. It shouldn't be pushed enough to heat up and trip the protective circuits. The only question might be whether clipping would damage the speakers. Or are you saying the sound quality would suffer if I used the receiver for those 3 speakers? Of course it depends on the volume, I guess. The receiver does have pre_outs.
  • ben62670
    Receiver amps are not like separate amps. It's all about current. Only a few receivers actually rate their power accurately. Also most will say something like "4ohm capable" all this is is current limiting. Apples, and Oranges. Ebay is a crap shoot. Audiogon.com , and the flea market here are pretty safe. Sometimes you can get lucky, and do local pickup. Receivers do kill tweeters;)
    Ben
    Ben
  • cfrizz
    Welcome to Club Polk.
    Your Sony does have preout for separate amplification. Your Sony does NOT put out 700wpc! It doesn't even put out the 100wpc when running more than 2 channels. Nor is it equipped to handle 4ohm speakers.
    What you THINK that it "SHOULDN'T" do & what it WILL do when running LSI's are two different realities.
    You will need to step up to the plate and purchase at least a 200wpc amplifier otherwise you put your receiver and more importantly your speakers at risk.
    This has been talked about many times here so do a search & expand your knowledge of the great speakers you bought.
    If you purchased used on Audiogon from someone who has good feedback you should be just fine.
    Brands to look for are Rotel, Parasound, B & K, Sunfire, Adcom, NAD.
    Outlaw Audio & Emotiva will also get you what you need. Look at Emo's XPA series.
    Owning the LSI's is NOT a cheap proposition & they need better electronics if you expect them to operate to their fullest capacity.
  • Pepi28
    Pepi28 Posts: 248
    Listen to what everyone here is telling you. I have a Sony 3000es rec. and didn't even fathom running 4ohm speakers let alone my LSi's off of it. I had my speakers sitting in their boxes for 3 months until I purchased the amps I have now. Buy used from audiogon, you will get more for your money and you definitelty will not regret it.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • HHStuart
    HHStuart Posts: 263
    cfrizz wrote: »
    I appreciate the feedback. I know the Sony doesn't have 700 wpc - sorry if it sounded like that. I guess I was thinking that I could take the load off the Sony by using a 2 channel amplifier for the LSi 15's. That would only leave the LSiC and the LSi 7's to be powered by the Sony. Granted that the Sony is not a high current amp and is not rated for 4 ohms, I thought that would still be sufficient headroom for only running 3 speakers - I don't think the LSi 7's are all that demanding. So far I've got The LSi 15's and the LSiC running off an older Sony at about the sound level of a Grand Piano and it sounds great (I had to turn my powered Subwoofer down). Of course, if I decide to play Also Sprach Zarathustra (very low bass organ at the start), all bets are off. That would need a black hole of power. So I guess people are saying that I would need to avoid using the amp on the Sony for anything?
  • HHStuart
    HHStuart Posts: 263
    ben62670 wrote: »
    Ben
    I'm sure you are right in that receiver manufacturer exaggerate their power. However, I keep hearing about low amp receivers killing speakers but I haven't killed one yet and I don't have high end stuff. Either I am not playing all that loud (or long) or I have had robust speakers. I started out with Dynaco A50's years ago and then added Dynaco A25's and powered all 4 of them with a Marantz 2230 (30 watts rms/channel). In 1987 I switched to Polk SDA 2's and never had a problem with them. The amp had 100 w rms/channel. I have played my music loud especially for parties but not all that often I guess. These were all 8 ohm speakers I believe. I'll keep an eye on Audiogon.com.
    Do you think I have to run all of the speakers of a separate amp or would just powering the LSi 15's off a 2 channel amp take enough of the load off for the Sony to handle the rest? Thanks for the input.
  • ben62670
    LSI's want power. Even a little Adcom GFA-535 with 80wpc at 8ohms will stomp most receivers out there. When amp shopping keep in mind that the LSI's are 4 ohm, and most dip to even 2ohms. That being said a typical 130wpc amp will put out roughly 200wpc at 4ohms. The 7's are fairly easy to drive compared to other LSI's.
    Ben
  • leroyjr1
    leroyjr1 Posts: 8,785
    I use Rotels 1075 and it does a great job with LSI 's.
  • curved
    curved Posts: 664
    My little 535 does a heck of a lot better job than my Yamaha AVR (at supposedly half the power - what a joke these manufacturer ratings are). The 535 doesn't even break a sweat....
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
