Worst case scenario if a faulty catalyctic converter is left unreplaced?
doggie750
doggie750 Posts: 1,160
edited November 2008 in The Clubhouse
Per my mechanic, he claimed it will not damaged anything! Engine and fuel will stay the same as is. Should I fire him now :confused:
Need advice from you guys. Thanks!
Vehicle: MPV Mazda 2003 3.0L minivan
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • MikeC78
    MikeC78 Posts: 2,315
    No, you'll be fine. However, your car will just result in more emissions to the environment and will probably fail SMOG.
  • strider
    strider Posts: 2,568
    Unless it's coming apart internally. Then it could clog and cause some serious driveability problems. Not necessarily the most probable thing to happen, but it is possbile.
    Wristwatch--->Crisco
  • bobman1235
    bobman1235 Posts: 10,822
    No, you'll be fine. Your car will just result in more emissions to the environment and will probably fail SMOG.
    Uhh, is that true? If it's clogged you could certainly see some negative performance impacts, eventually coming to the point where exhaust would be backing up. Engines don't tend to like that.
  • dkg999
    dkg999 Posts: 5,647
    Until the converter plugs up, then the vehicle won't run. I had a friends car that one day just wouldn't start. The mechanic checked everything, worked on it most of one day, couldn't find anything amiss. Another friend of his worked at a dealership and had seen this scenario several times, dropped the exhaust pipe, and it fired right up. He said that when a cat converter stops working, it's only a matter of time until the insides come loose and cause a blockage.
    DKG999
  • MikeC78
    bobman1235 wrote: »
    If it's clogged then there would be an issue. However, I'd be hard pressed to find an '03 in that bad of shape. I have a '94 van that has the original cat with no issues, but anything could be possible. If there isn't any driveability issues, I'd be hard pressed to assume it's clogged.
    Anyway, what makes you think or your mechanic think that it's faulty? If it's throwing a code, I'd check the O2 sensor first, those usually go bad way before I'd claim a faulty cat. Sometimes you can get away with a good cleaning, usually they have to be replaced.
  • MikeC78
    Anyway, you guys would be correct as to assume that'd be the worst case scenario.:) I'm trying to be a little optimistic here.
    Seriously, I'd try to steer clear of replacing the CAT, they are not cheap to replace. I guess I'd wait until it caused more issues down the road and you are stuck somewhere.:o (worst case scenario)
  • Fongolio
    Fongolio Posts: 3,516
    I've had one clog up and get so hot it glowed red and started my carpet smoldering. Be careful.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • SolidSqual
    SolidSqual Posts: 5,218
    Fongolio wrote: »
    +1 here. Led to an overheating issue in my tahoe.
    billbillw Posts: 7,787
    Yo Doggie, how many miles on that MPV? Most manufacturers have a pretty long warranty on emissions equipment, many times at least 80K and often they will extend for things like Cats. Check with Mazda USA or the local dealer.
  • strider
    billbillw wrote: »
    Good call, completely slipped my mind.
    heiney9 Posts: 25,497
    If it gets plugged bad enough it might get hot and could start glowing cherry red. If it gets to that point of being severely clogged you will damage your engine. Most newer cars use 2 or more oxygen sensors to lean/enrich the fuel mixture; among other sensors and devices. Extreme lean or rich conditions can do other damage if your not careful; worst case scenario.
  • Face
    Face Posts: 14,340
    heiney9 wrote: »
    +1!
    Damage, if not even cause a catastrophic failure.
    Either replace it or have a "test pipe" installed until you can afford to replace it. Just be warned, a test pipe should trigger the SES light and will cause you to fail a emissions inspection. And if you get caught, it's a hefty fine.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    I would replace it ASAP because you are hurting the environment more not to say that i care that much but i do in another way care.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
    Also catalytic converters have come way down in price in the past 5-7 years. The dealer is ridiculously priced but aftermarket CC's are excellent and very inexpensive for most cars.
    I would check your warranty as emissions parts have to function for a predetermined amount of time as mandated by the gov't and the manufacturer has to replace worn or faulty parts within some sort of warranty.
  • Face
    Face Posts: 14,340
  • Kris Siegel
    Kris Siegel Posts: 309
    Well that's crazy timing. My cat appears to be going up as well on my 2001 Chevy Prizm. Damn thing has over 110k miles on it so I may just end up getting rid of it (it has other issues).
    I had a 1991 Volks GTI the cat went out at 130K, the insides rattled horribly and the exhaust smell would choke you. I replaced it with an OEM cat (not bought from the dealer) for $99 and I sold the car with 200K and it still worked like new.
    Granted this was a few years ago. I let it go way too long and the resulting lean mixture burned up the cat.
  • bigaudiofanatic
    Our honda had its stock one on for the time we owned it 298k miles later it was gone but never had to replace the cat or anything rely big the only thing was a radiator.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • sucks2beme
    sucks2beme Posts: 5,691
    Here in Texas, they just check for codes on newer cars. No tailpipe check.
    So as long as the cat doesn't set check engine, I'm good.
    If it clogs, it's like the old potato in the tailpipe trick. It won't start.
  • John30_30
    John30_30 Posts: 1,024
    Don't wait until it clogs. When they disintegrate like that, they're "supposed" to just drop that set of baffles so the exhaust flows on. Sometimes yes, sometimes no.
    If no, it'll screw with performance. Go to a muffler shop and either have them cut it out and replace with straight pipe, or replace it.
    The real auto guys here can set this straight- that's just what I get from my buddy who owns a shop.
    I'm pretty sure California mandates you have to have one, maybe states back East also because of the smog- I know out here in the Southwest, it's not law. Check your state regs to see if you can even legally put a pipe in.
  • Face
    Face Posts: 14,340
    John30_30 wrote: »
    It's federal law that you must have one. Some states such as NY, CA, NJ, etc...have stricter standards than other states.
  • ben62670
    ben62670 Posts: 15,969
    I don't need one:)
    Ben
  • Face
    Face Posts: 14,340
    I should elaborate, if your car came from the factory with one, you need to have one on there.
    Ben, we all know you're special. ;)
  • BrettT1
    BrettT1 Posts: 560
    They don't do any vehicle inspections in Oklahoma anymore. I see cars not road worthy quite often. I guess they don't care if someone gets hurt.
  • ben62670
    Face wrote: »
    1968 Bronco:D
    No seat belts either, but I am going to add them. Stopping real quick even with 35's, and 7.5 inches of lift being shorter than a CJ7 in wheelbase can be hairy even with 4w disc brakes:eek:
    Ben
  • Jstas
    Jstas Posts: 14,996
    If you tamper with a emissions control system on your vehicle with less than 80,000 miles on it and it ain't broken, don't get caught because fines are stiff and if the judge feels pissy that day, a first offense brings up to 2 years in jail with it. And that's not sissy county or state jail either. That's Federal, pound-me-in-the-**** jail. Oh yeah, your hot rod you had when you went to jail, will have likely had it's appointment with the crusher long before you get out early on good behavior.
    Expert Moron Extraordinaire
  • mantis
    mantis Posts: 17,559
    +1. You gotta replace it anyway so why wait? I know spending the money on it sucks but it's something you have to do.
    It will start to cost you money in gas, it will hurt performance after it starts to break down, then your car will not start once it closes completely.
    Dan
  • ND13
    ND13 Posts: 7,601
    Most emission components are covered under warranty for 80k miles.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • doggie750
    thank you for all the input, much appreciated!!!!!!!
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
