RTi-12 problem
ronnie
ronnie Posts: 150
edited November 2008 in Troubleshooting
i blew out my tweeters not to long ago...i paid for the replacement tweeters and installed them. now my right side tweeter is not working..i know it's not the tweeter because i swapped it with the other one and it works. my speakers are bi-amped and the mids are working just not the tweeter...so what could be the problem...what do i need to fix this...im not sure whats wrong with it...
Yamaha RX-V2600
Adcom GFA555 x 2 :D
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
Post edited by ronnie on
  • Jed Leland
    Jed Leland Posts: 183
    Hello,
    I would imagine you've blown out the speaker's crossover. That and the tweeter are the only two parts of the speaker.
    Cheers, Jed
  • ronnie
    ronnie Posts: 150
    so how do i go about fixing it....
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • megasat16
    megasat16 Posts: 3,521
    Best thing is to call Polk CS and they'll guide you step by step to remove the XO from the speakers. You can make a quick visual check (and smell check too) to see if anything obvious had happened to it. The XO can be repaired and needs to send to Polk for repair if your RTi12s are under warranty. Or you may attempt self-repair if you are hands on with soldering gun.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
