LSi9 Crossover Upgrade
Face
Face Posts: 14,340
edited November 2008 in Speakers
After reading the reviews on how upgraded LSi crossovers made such a improvement, one of our members here trusted me to upgrade the crossovers in his LSi9's.
I briefly went through the upgrade threads and pics from Darque Knight, Ben, and Madden, taking ideas from all three.
Disassembly wasn't too bad. The speaker connectors were a little stubborn, but a little DeoxIT fixed that. The next obstacle was removing the caps and resistors off the stock boards. After snipping the leads, the film caps and small electrolytic came off easily. The larger electrolytic had to be mutilated on one of the crossovers. On the first board I didn't attempt to remove the resistors since I read that the board could be easily damaged. I decided to give it a try on the second crossover though. I placed the side of the board and resistor in the palm of my hand, placed my fingers on the other side of the resistor, and pulled in. Surprisingly, the resistors came off without much effort. I also had to partially remove the 1.2mH inductor to get to a capacitor solder lead. I desoldered one lead on the inductor and lifted it up a small bit to get to access it.
Assembly of the first crossover is what was the most time consuming. In the end, I decided to flip the board and mount all the caps standing up. I used a few drops of hot glue on each cap for support them and to prevent vibration. As for the 260uf cap, it was replaced by 2 100uf and 1 60uf Daytons mounted to a 1/4" piece of MDF. I then used industrial strength velcro to attach the board to the speaker cabinet in case it needs to be removed one day.
IMO, in comparison, a stock LSi9 sounds kind of closed in. After modifications, right out of the box there is more detail up top, mids are clearer, bass is better defined, as a whole, the speaker sounds much more open. I can't wait to get a few more hours on these. I also can't wait for their owner to hear them. Paired with his new DSW sub, he's going to have a very nice sounding 2 channel rig.
Here are some pics:
Post edited by Face on
  • leroyjr1
    leroyjr1 Posts: 8,785
    what did that xo mod co$t?
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    I too would like to know how much they were and if they would work on the Lsi7s. Also are they interchangeable in case I like the originals better?
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • dorokusai
    dorokusai Posts: 25,577
    Great work Face.
  • george daniel
    george daniel Posts: 12,096
    Very nice work sir.
  • fossy
    fossy Posts: 1,378
    I wanna hear a pair of hotrod 9's dangit . Much more open is a good thing.Nice work.
  • Face
    Face Posts: 14,340
    Thanks guys!
    As for cost, I believe the cost was in the ballpark of $225-250 for the pair.
  • ben62670
    ben62670 Posts: 15,969
    Awesome:) I so love this mod. Like you stated even just hot off the iron the mod will surprise you. I feel it is an even more of an improvement than modding SDA's. It truly is like a whole new speaker. The owner will be proud.
    Ben
    Ben
  • mmadden28
    mmadden28 Posts: 4,283
    Nice Job! Wow you really cleared that XO on the one side huh?
    ____________________
    Pool: Atrium 60's/45's
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Nice job Mike! I think Ben has some competition for his speaker mod business.:)
