AQ G-Snake for Subwoofer or long run to 2nd zone?
mmadden28
mmadden28 Posts: 4,283
Is $1/ft of unterminated bulk Audioquest G-Snake a good deal?
There's some on the bay (hundreds of feet avail in spools).
How about the quality of the cable itself-is it ideally suited for subwoofer duty?
What about for a longer run from the pre to an amp for a unpowered 2nd zone? (note the 2nd zone would like be outdoor/non-audiophile level)
____________________
Pool: Atrium 60's/45's
Post edited by mmadden28 on
  • mantis
    mantis Posts: 17,611
    edited October 2008
    Audioquest makes fantastic cables. I swear by them. At all levels. I use Ita 1.1 for my sub and would use it for a zone 2 amp. Audiophile or not. It's a good quality cable. the G-snake is also a good quality cable which is about the same as the Ita 1.1.
    You need to have the ends and the correct tool to stripe the wire. Correct termination is key to the overall quality of any cable. Screw that up and it doesn't matter how good the cable is.
    Dan
  • mmadden28
    edited October 2008
    Aw crud-What the hey, the listing was removed. :confused:
    Its still listed int he store, but can't click on it.
    Thanks Mantis.
  • mmadden28
    edited October 2008
    Looks like thay also have bulk, no braided jacket, AQ Copperhead cable for $3/ft.
    Oh wait a minute-the bulk G-Snake for $1/ft is back-must have been a hiccup.
    :confused::confused:
  • mmadden28
    edited November 2008
    mantis wrote: »
    You need to have the ends and the correct tool to stripe the wire....
    What special tool is required for this type cable?
    Is the Copperhead worth 3 times as much as the G-Snake?
  • miner
    miner Posts: 1,305
    I use a 12' pair of G-Snake for my Dynaudio Sub20A. I am happy with it, better than my *onster brand.
