SDA Interconnect
abmarsh
Does Polk sell SDA interconnect cables to replace lost or damaged items? It's not in their parts list.
Post edited by abmarsh on
It's listed as a SDA cord, but last I heard they only had the twin blade type. If you need a pin/blade type then you'll have to make one or Har has one for sale that he made, looks nice.
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=7260Political Correctness'.........defined
President of Club Polk -
From what I understand, the blade part is there to hold the pin in place. Prior to finding one from this website, I used speaker wire which was recommended from Polk tech support. It will produce the same effect and is easy to make. Rat Shak has a pin that you can crimp on the wire and fit into the hole.
