Squeaky 2.3 Driver
Huh What?
Huh What? Posts: 55
edited October 2008 in Troubleshooting
I have a pair of the SDA 2.3 speakers that have the donuts on the top and bottom drivers of the outer columns. At higher volumes, they make a squeaking sound (both speakers). It's not a fuzzy sound like a blown driver. Initially I thought it might be loose grilles, but after removing them I placed my hand on the donut at volume and the squeek went away. At moderate volumes it disappears. Has anyone had this issue before? If they need replacing, I'm pretty sure I'd have to go with the updated driver. My concern is am I going to have to rebuild the crossovers too for the new drivers?
Home Theater - Talon Firebird (Fronts), Talon Raven 2002 (Surrounds), Talon Cinema Hawk (Ctr), Talon Falcon (Back Surrounds), JL Audio Fathom F112 Sub
Pre/Pro - Classe SSP-800
Amps - Sim Audio Moon Titan 5 channel, Modwright KWH 225i
Blu-Ray - Oppo UDP-203
Projector - Epson PowerLite Home Cinema 5040UB
Screen - Silver Tickets MPT 110"
Primary 2 Channel - Talon Firebirds
Modwright KWH 225i Integrated Amp
Oppo BDP-103, Audio Research DAC 8
Secondary 2 Channel - Polk SDA 2B
NAD T775, Denon 2900 DVD-A/SACD
Post edited by Huh What? on
    F1nut Posts: 50,836
    edited October 2008
    I think your problem is that the donut is separating from the cone.
  • Huh What?
    Huh What? Posts: 55
    edited October 2008
    Do you know if that's something that's repairable, or is it new driver time? My silicone, soldering, and JB Weld skills only go so far.
  • zingo
    zingo Posts: 11,258
    edited October 2008
    I would contact Polk customer service and see if they have dealt with this problem before. I would think it would be repairable, but the wrong adhesive might damage the cone.
    F1nut Posts: 50,836
    edited October 2008
    It was glued on to begin with, so you can reglue it, if that is the problem. You can't buy a new driver, so you better hope it's repairable.
  • Face
    Face Posts: 14,340
    edited October 2008
    LOL @ the JB Weld.
    F1-Does Polk carry a driver that could be used in it's place?
    F1nut Posts: 50,836
    edited October 2008
    Not to my knowledge.
