RTi Series
silverblur
I was looking at the RTi12 awhile back and Frys had them on sale for $700/pair. Now that the RTi series is obsolete and the replacement is RTiA7/A9, does anyone know when these might be on sale or where to find a deal right now
thanks!
thanks!
Post edited by silverblur on
Try amazon or ebay. Also look at you local craigslist.
I hope you have a good amplifier or receiver for a speaker that size. All those drivers take a lot of hefty power.Alea jacta est!
Look at audiogon there is a pair of rti 12's and rti a9's for sale.
I have Onkyo 805 - hopefully that's enough power -
silverblur wrote: »I have Onkyo 805 - hopefully that's enough power
Nope it wont be, it will be enough to hold you over until you can buy a power amp. Most hear will suggest an external power amp.Shoot the jumper.....................BALLIN.............!!!!!
Onkyo rate their receivers two channels driven. At least they are honest about it and state that clearly in their specifications. The true output with five or seven speakers is probably half of the published two channel output, or less (maybe 50w/ch for the 805) in normal use. This is not specific to Onkyo and does not mean that it is not a good receiver BTW: most brands do the same, with some noteworthy exceptions, such as harman/kardon (for the same price range as your Onkyo, they will only claim 50-75w/ch all channels driven simultaneously) or NAD (you would have to pay about $2,000 to get a model claiming about 100w/ch, all channels driven).
http://onkyousa.com/model.cfm?m=TX-SR805&class=Receiver&p=sAlea jacta est! -
Check Amazon.com or J&R. J&R just got a new shipment of RTi12's from Polk, and are selling them for $800/pair + shipping. I'd definatley buy a pair if i didn't already have the 10's!!KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
I have the Onkyo 805 / RTI A9's and the Onkyo does a decent job with those speakers, but when you add external amp into play it wakes them up. When running in 5 channel stereo I noticed the bass to a dive and sounded flat, but in 2 channel mode it did a better job.
The Onkyo will hold you over until you get a external amp. Also you don't have to spend alot on a amp to make them sound got . A $200 adcom 545II or 555II wll be enough. -
What freq do the woofers handle, and how much of that required driving power is actually handled by a sub when running with a crossover at 80Hz? Anybody?
I'm thinking that if you're using a sub, you'll be giving more available power to the 12s, however if you not running a sub, then....
??____________________
Pool: Atrium 60's/45's -
... I'm thinking that if you're using a sub, you'll be giving more available power to the 12s, ...Alea jacta est!
... Also you don't have to spend alot on a amp to make them sound got . A $200 adcom 545II or 555II wll be enough.Alea jacta est!
Probably true, but still probably not enough power available. Remember the RTi10 and RTi12 have subwoofers included, not just midwoofers and tweeters, so they need the power since they do not have their own built in amplifier like a seperate subwoofer would normally do. JMO, but paying extra for big speakers and not being able to get the benefit would be disappointing.
They don't have a built-in passive sub, the RTi12's have three 7" woofers. It is rated to go down to 18Hz, but its really 30Hz at -3dB. Sure you're not thinkin about the LSI floorstanders w/ built in subs?
I'm currently running my RTi12s with an Emotiva XPA-5 which is more than enough power, and I've tried them large with no sub and they do not go nearly as low as when using an external sub. Of course its always possible I didn't have it setup right. but I didn't spend too much time on it since I have a sub. I do however sometimes feel like its a wast to have such nice bog speakers but likely only using the upper half of them.____________________
... the RTi12's have three 7" woofers. It is rated to go down to 18Hz, but its really 30Hz at -3dB. ...
There are plenty of threads where owners struggle to get their RTi10 or 12 to perform like they would expect. You yourself chose to use an external amplifier. New buyers should be aware of the challenge when they are going to use a receiver like the Onkyo 805 for speakers such as these. After that, the it's up to them to decide what they expect in terms of performance and what they want to do to achieve that goal.Alea jacta est! -
I'm not convinced by this argument. I tried an entry level Emotiva amp a while back (LPA-1), and was very disappointed to find that, in a blind listening test, using identical pairs of speakers side by side and the same source, I could not notice the improvement of the claimed 125w/ch external amplifier when compared to a 40w/ch harman/kardon. YMMV, but beware of paying hard earned money for entry level amplifiers if you are expecting miracles! (If money comes easy, however, then sure: go ahead and try it for the fun of the game.)
The Adcom 545 is probably the best bang for buck amp out there. It ran my RTI A9's without any problems and only rated at 100 watts. When comparing a amp vs receiver you will notice a bigger difference when listening mid to high levels. Listening at low levels you probably will not notice any difference.
When running My 9's with my 805 it sounded great a low to mid level but when you cranked it thats when you could tell the difference in SQ. -
... When comparing a amp vs receiver you will notice a bigger difference when listening mid to high levels. Listening at low levels you probably will not notice any difference. ...Alea jacta est!
Sorry, but I'm still not convinced! I know all the arguments for and against, including that one, and can list them all to you from now until Christmas, but my experience with the LPA-1 demonstrated that not all amplifiers are necessarily equal, nor are they necessarily better than all receivers, since all receivers are not created equal either! YMMV.
You're not serious.....are you?? If you can't hear the difference between the two that you had a blind test with, you probably never will.....
With my RTi8's, it was an insane difference!! Night and day.....Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
http://www.polkaudio.com/forums/showpost.php?p=769578&postcount=153
To be fair, others have had a better experience, so this unfavorable (for the Emotiva LPA-1) result could be due to the limitations of these speakers, or the source used, or other things entirely. Still, a night and day experience it certainly was not and few others have gone to the trouble of a true blind test rather than trusting to judgements that have been influenced by all the hype surrounding Emotiva.
Buyer beware nonetheless. People pontificate about external amplification all the time (I have done so myself before this test was concluded), but perceptions are subjective and that can influence an unbiased result. I had my doubts and didn't want to make a wrong choice, so I did the blind test. I was as surprised by the result as anyone. The truth about external amplification probably still holds, but again, not all amplifiers are made equal and not all are necessarily better than a good receiver.
The only way to be sure is to do like I did: buy the amplifier and, if you don't like it, sell it at a reasonable loss, or eat the shipping costs back to Emotiva. Otherwise, find a store where you can listen to both (Emotiva only sell direct, so that will not be an option) and pay store pricing, or find a Polk user where you can listen for free (bring a good bottle of wine or something).Alea jacta est! -
Silverblur
Keep your eyes on polk direct ebay store they have good deals from time to time on
RTI A7's and RTI A5's if either may be a option. Sorry about getting off topic about amps and everything.
All three rtia 5,7,9's all sound good and will be a good choice. There is some rti 10's on ebay right now. -
Thanks for all the replies!
Summaries of the posts:
805 is does not have enough to power rti12....so I will go with rti10/rtiA7 and a sub
My applications (in order of importance) are
1. Karaoke 2. Music 3. HT.
So the midrange from rti10/A7 will be great
I need recommendation for center and in-ceiling for surrounds -
I have a pair of black RTi10's I'm wanting to unload at a very reasonable price. Where do you live?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
silverblur wrote: »Thanks for all the replies!
...or RTi12/RTiA9 (or anything for that matter) with an Onk 805 and an external amp.
Actually when using an external amp(a quality capable one), the power capabilities of the AVR is irrelevant, the only thing it does then is function as a Preamp/Processor, so use of an external amp can be applied to any AVR in this sense.
Center-
CSi5/CSiA6____________________
