Which fuse..?
Jeff Beaird
Jeff Beaird Posts: 217
edited September 2008 in Troubleshooting
I bought another pair of Monitor 5jr's on Ebay, unpacked them and fired up in the Garage... Kenwood pre, Yami cd changer, Adcom GFA-1a amp...
Warmed them up a little with some Nickelback...
After 15 min. turned up some Kutless:D and POP!... the fused blew! Both 'em..?
Not more than 4 on the Volume..?
It was loud, but enough to blow the fuses?
I guess my ? was, do fuses get old? And which is the correct replacement fuse for 5jr's..
Thanks Guys and Gals! God Bless!
Thanks, Jeff...
Post edited by Jeff Beaird on
  • dorokusai
    dorokusai Posts: 25,577
    No. 1A 250V BUSS.
  • ben62670
    ben62670 Posts: 15,969
    Are there 2 fuses per speaker, or one?
    Ben
  • Jeff Beaird
    ben62670 wrote: »
    Just one fuse... another question I have,
    Will a loose fuse holder affect SQ?
    Thanks, Jeff...
  • ben62670
    It can. I had a few. Try to tighten it up with some needle noses before putting in the new fuses.
    Ben
