Talk Me Through....
wingnut4772
wingnut4772 Posts: 7,519
edited September 2008 in Troubleshooting
...a ground loop please. At least I think that's what it is? It's not a hum per se but rather an annoying buzzing in all the speakers. I can't seem to isolate it.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
    treitz3 Posts: 19,274
    Darla, you have to get rid of the ground pin on one or [possibly] all of your PC's that are plugged into the wall. If you can't do that, get a cheater plug. Are your IC's parallel with any of your PC's?
  • hoosier21
    hoosier21 Posts: 4,413
    do you have cabel TV? Is it connected to this system?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    Ah, that would definitely do it. ;)
  • wingnut4772
    hoosier21 wrote: »
    Yes satelite but I unplugged it already and it's still there. I also took the ground prong off my amp and it helped somewhat but it's still there.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • wingnut4772
    treitz3 wrote: »
    Probably. I haven't donay any cable management yet as I am still configuring..etc..
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • steveinaz
    steveinaz Posts: 19,538
    Is there any flourescent fixtures/refridgerators, etc on the same circuit? This would include CFL bulbs? A buzz is usually an appliance/fixture, or signal/AC lines too close. Hum is related to different potentials on ground between 2 or more components.
    Sometimes 2 pronged ac equipment doesn't play well with 3 pronged equipment. I found this out with my Panasonic BluRay player, even though all equipment was plugged into the same power supply.
    The easiest way to isolate a ground loop hum is to pluyg equipment in 1 at a time and listen for the introduction of hum. Start with amp-speakers...listen, then add 1 piece at a time. Once you find the culprit, there's a number of different approaches. Lifting the gorund on the power amp (not recommended), turning the 2-prong plug 180 degrees if not polarized, etc, etc.
  • wingnut4772
    Cheater plugs did the trick. It's super quiet now. Thanks guys.:)
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • mmadden28
    mmadden28 Posts: 4,283
    What specific piece of equipment was it that caused the most annoyance?(that resolved with a cheater plug)
    ____________________
    Pool: Atrium 60's/45's
  • wingnut4772
    I just hit all the main suspects. I didn't go 1x 1 yet. I will narrow it down later. Mainly the PS3, receiver, amp and satellite box.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • okiepolkie
    okiepolkie Posts: 2,258
    Here is one of the best way to get rid of ground loops, and still keep the safety of the ground pins:
    http://www.jensen-transformers.com/
    Tschüss
    Zach
