tuner troubles ............need ideas
Deadof_knight
OK I have a Denon 3300 in my front room , I have 3 other denons and no trouble... Here is my problem I cant get any well hardly any reception on my 3300. I curreently installed a Terk amplifier and have it turned 3/4th of the way up. and I still get fuzzy reception on a station thats only a few miles away what gives in fact its not all that much better than when I didnt have the terk hooked up ....Im kinda at a loss here I had the 3300 installed in my other house and had no troubles....need ideas and or suggestions...here
:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
Post edited by Deadof_knight on
Try the 3300 in another location/room. It might be a dead spot caused by construction materials. e.g., I have problems w/ radio reception in areas of our house due to metal lathe that supports the plaster on the walls. Other issues can be things like aluminum siding and foil covered foam insulation panels.
Cheers, JimA day without music is like a day without food. -
my suggestion.. get an analog tuner.. the old fashioned kind like Sansui, Pioneer or Marantz. they don't cost that much.. and I betcha reception will no longer be a problem.
I have one of them "T" shaped thin wire antennas connected to my Pioneer TX-9500II and the reception is maxxed out on most stations. I can't even imagine how far way stations I could dial in if I had a decent antenna.. instead of the dime one I'm using now.
Analog tunas rule. Enough said.PolkFest 2012, who's going>?
I have found that for whatever reason some tuners do not work well with amplified antennas like the Terk. I would try a simple non amplified antennae like Danger Boy is suggesting and see if that solves the problem.
Jim Shearer wrote: »Try the 3300 in another location/room. It might be a dead spot caused by construction materials.
Cheers, Jim
Good cheap idea. -
lakesailor wrote: »I have found that for whatever reason some tuners do not work well with amplified antennas like the Terk. I would try a simple non amplified antennae like Danger Boy is suggesting and see if that solves the problem.
I don't think a cheap non amplified anntenna will solve his problem. the problem is with some tuners themselves.. they just aren't built with decent tuners in receivers.
But I do agree.. proper antenna placement is key to good signal strength no matter what tuner you are using.
Overall my experience has been that digital tuners lack the strength to dial in some stations.PolkFest 2012, who's going>?
Install a small FM antenna in attic.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Amplified antennas just amplify the noise and the FM signal. They help however if you want to use the antenna for two tuners.
Receivers for the last 15 years have tuners that cost the manufacturer about $2.
You get what you pay for.
The Sony HD tuner is a great deal. -
well I got sirus on the dish ...but Im partial to some of the local stations when im home. I had been thinking about a tuner antenna in the attic previously guess I have my answer now:cool: " He who dies with the most equipment wins Right ? "
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Have you tried Rabbit ears. They work better than most amplified antenna and look better than the wire T ones.
+1 on the attic antenna. -
take that tuner to one of the other rooms where there aren't the problems and try it there. I found a digital source can wipe out FM. If there is a DVD/CD player in the room where it doesn't work, turn it off and/or unplug it. Not all players will do this. So try those things and report back. Good luck!
ET
System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant! -
I have found the sometimes the single wire that they include with the receiver works better than amplified anrennas
danger boy wrote: »my suggestion.. get an analog tuner.. the old fashioned kind like Sansui, Pioneer or Marantz. they don't cost that much.. and I betcha reception will no longer be a problem.
This is a great idea!
