which amp to drive my lsi15's?
troygray
troygray Posts: 6
edited September 2008 in Speakers
I've been building out my new system and I am a definite newbie. I have had many recommendations I should get a separate amp for my lsi15's. I also have a onkyo 806. Could someone please help me my selection. $ is definitely a concern because I've broken the bank.
Also if there is anything you have seen in the classifieds, please let me know.
Post edited by troygray on
  • leroyjr1
    leroyjr1 Posts: 8,785
    What is you budget and are you doing home theater 5.1 or 2 channel audio?
  • be83663
    be83663 Posts: 192
    troygray wrote: »
    I have an Outlaw amplifier, and I like mine. There are also Emotiva amps that are affordable. You can get either one for about $700 for about 115 wpc for 7 channels. They are both online only companies; and that makes their products cheaper compared to the ones that have dealers at local audio shops, like Rotel, Parasound, Anthem, and whatnot. If you don't mind buying used, then I guess your choices are expanded more. :)
  • VXR8
    VXR8 Posts: 291
    I'll second the Emotiva stuff. You can get the XPA-5 for $799 or the XPA-2 for $799 also. The XPA-5 will give you 350 watts x 5 or 450 watts x 2 channels into 4 ohm, or the XPA-2 will give you 500 watts x 2 into 4 ohm. Check them out and let us know how you go.
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • garnier
    garnier Posts: 116
    VXR8 wrote: »
    The only thing about Emotiva in their specification is that their watts-per-channel numbers are given only at 1 kH whereas, Outlaw's is from 20-20,000 Hz. I guess, with this catch considered, XPA-5's true rating for 5 channels should be less than 350 wpc.
  • gtu2004
    gtu2004 Posts: 620
    what receiver would be able to drive these without an extra amp? I have an Onkyo HT-R540 and while I don't think it'll be good to drive LSi15s to half their potential, would it suffice to drive them without breaking the speakers?
    Onkyo 805, RtiA5s, Csi5, Rti6s
  • leroyjr1
    gtu2004 wrote: »
    Running LSI 15's will put alot of strain on any receiver a external amp is recommended.
  • leroyjr1
    troygray wrote: »
    Used Adcom gear is very reasonable. That's where your going to get you money worth.
    If money is tight I would look at:
    Adcom 545II 150watts@4ohms (around $200)
    Adcom 555 325watts@4ohms(around $300)
  • curved
    curved Posts: 664
    garnier wrote: »
    You might want to check your research on that quote. The Emo rep came on here and explained this....
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • garnier
    garnier Posts: 116
    I have an Outlaw Model 7700 7-channel Balanced Amplifier for 300 watts/channel @4-ohms, and I am very pleased by its performance. If you are looking for a new unit, then it would be something to consider too. There is Model 7500 5-channel Balanced Amplifier also for the same power rating for $550 less. :)
  • Kex
    Kex Posts: 5,233
    Check NAD receivers. They are expensive new and not all that common used, but they have a reputation for very powerful output at 4 ohms and can sometimes be found on eBay, Audiogon, craigslist.com ... There are several Club members that use them.
    http://nadelectronics.com/products/av-receivers
    http://spearitsound.com/nad/nadspec.htm
    Alea jacta est!
