Polk Cs 350ls
mon10b
Hi to all , i am somewhat of a newbie on here since i've nevere posted until now . My question is i have a Polk cs 350ls that i just purchased recently and at low volume the left two 4.5 mid-woofers have a buzz (mostly the outer one) . When i turn up the volume it goes away . I know this speaker is rated from 10 to 250 watts , am i not driving it enough causing the buzz . I live in an apartment building so i cant shake the walls late at night . Im using a Sony DB930 110 watt x 5 driving a pair of SDA 1's for stereo music and monitor 10b's for L/R the Cs350ls in center and paradigm titan's for surround with 2 Cerwin Vega 12" 150 watt sub's in home theater mode . Any help is appreceiated , Thanks much . Mon10b
Post edited by mon10b on
well, I am not sure about your set up you are driving SDA and the 10B's with your receiver? Have you or can you try a different center speaker to see if the sound is still there? You say it goes away at volume, but could it be that it is there but you can no longer hear it?
RT1 -
I think you misinterpered what i wrote . I use the SDA's for stereo music only , when i go to home theater mode i turn them off and turn the rest on . Yes i do have another speaker for the center it is a Cerwin Vega ec-76 . Which sounded perfectly good . I happened to get a deal on the Polk and thought i would give it a try . Is it possible that 1 or 2 of the mid woofers is blown on the left side ? Can i get replacements for them ? Thanks again , Mon10b
Replace the center with a different speaker and see if the sound (hum) goes away. Or simply swap speaker wires on the reciever. Was the Polk center dropped? I've seen the magnets on the back of the woofer shift slightly to rub on the voice coil which is noticable at low volumes and it takes a very good ear to hear at normal listening levels.
My $0.02Thanks, Jeff... -
Thanks for your help Jeff , i will post a reply when i get a chance to switch them around .
Selling POLK CS350LS Center Channel. Excellent Shape best offer.... shipping not included columbia, md 21045
joseph.v.chen, please don't spam this post and post-jack. There is a for sale section on the forum for this purpose, and there is a reason you weren't able to post there. Please read and abide by the forum rules:
http://www.polkaudio.com/forums/announcement.php?f=10 -
did not mean to spam the thread. I am slowly getting familiar with the forums and navigating around. just let me know if and when i get off track and I'll make the best attempt to resume the straight path...... thanks
