Hum - Low Volume - amp?
ajanzalone
ajanzalone Posts: 128
edited September 2008 in Troubleshooting
Well I was just starting to enjoy my vintage stereo system again ....
Audio Research SP5 - Quad 405 - Polk Monitor 10's
Then, of course, I turned it on today......
with the volume set at "0", ...........
Immediately a grumbling was heard through both speakers .....
I turned the volume up a notch and the grumbling went away, return to "0" quiet ... ok
I then noticed a very low hum in both speakers. I had to get within 6 inches to hear it.
I set the pre-amp to TV, turned the volume up 1- 2- 3- 4- 5 then 6,
(about 40% volume), and it just started to sound like normal level .....?
Normally it gets loud enough to rattle the windows on 4 .....
I checked the amp fuse and it was OK
I suspect the sound I was hearing through the speakers was from the pre amp's output of 10/15 or 20 watts?
So, did I blow an amp or capacitor?
Any thoughts as to what this could be?
amplifier caps ? ..... or power section ......?
Of course, I have been anxiously awaiting the arrival of my new DV-48AV, (DVD/SACD player),
which will be here tomorrow, according to UPS:(
Tony
Audio Research SP5 Preamp
Quad 405 Amp
Pioneer Elite DV-48AV -
Outlaw 950 preamp/processor
Polk Monitor 10's
Velodyne VRP 1200 Sub Woofer
Success is having what you want ... but Happiness is wanting what you have!
Post edited by ajanzalone on
  • ajanzalone
    Is there a way to test the voltage at the "Amp & Pre-amp" so I can narrow down as to which unit is at fault?
    Tony
    Quad 405 Amp
    Polk Monitor 10's
  • ajanzalone
    Keiko wrote: »
    I'm not an expert on this but a couple things I can suggest is checking your interconnects and use good quality, well shielded IC's. A good surge/power conditioner certainly wouldn't hurt either.
    Yeppers..clean the interconnects ..........
    I opened the Amp..
    Checked all the fuses.. all OK
    I cleaned the Quad proprietary - DIN contacts and the RCA contacts with a soft pencil eraser ....
    Hooked everything up.... and Viola .... loud and clean again....! Got me stumped ..... ?
    Hooked up the New Pioneer Elite DV-48AV, (DVD/SACD player) with some standard CD's .. WOW! .... more musical then I have ever heard them..
    I can't wait for the SDCD music to arrive, that I ordered....
    Thanks Tony
    Quad 405 Amp
    Polk Monitor 10's
  • ajanzalone
    Keiko wrote: »
    Cool! Wait till you hear what SACD delivers. :D
    Might want to consider investing in some good interconnects and speaker cables Tony. It only gets better. Welcome to The Dark Side bro. ;)
    I have already replaced all my RCA to RCA connectors to Gold tipped cables from "Monoprice.com" ......
    but the Quad amp has a proprietary DIN to RCA cable and I have not found one in Gold yet .... I even called Quad ....:(
    Yep I am getting excited:D
    Tony
    Quad 405 Amp
    Polk Monitor 10's
  • ben62670
    ben62670 Posts: 15,969
    You can send me your din cable, and I can build you one in silver?
    Ben
    Ben
  • ajanzalone
    ben62670 wrote: »
    Ben
    Ben:
    Thanks for your offer ....
    I have not yet decided if I will upgrade to a newer amp ...
    or get the Quad 405 updated by data techs ........ who make this product and more.
    They have a local tech that will install and test the Quad 405 rebuild ....
    http://cgi.ebay.com/Quad-405-High-End-replacement-board-with-OPA627_W0QQitemZ130243103993QQcmdZViewItem?_trksid=p3286.m20.l1116
    I just found this cable on ebay
    http://cgi.ebay.com/4-Pin-DIN-to-RCA-Quad-33-44-303-405-to-RCA-Amp-Cable_W0QQitemZ110286699851QQcmdZViewItem?hash=item110286699851&_trksid=p3286.m63.l1177#ebayphotohosting
    Tony
    Quad 405 Amp
    Polk Monitor 10's
