center channel
dholmes
I saw a picture of a system with the center channel on steriods, it had 3 spks, would there be any benefit to this,or would it be better to add a sub to make the center more beefy. I wanted to do something like this to give my center more kick I have a cs400 Thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
Talk to Scottvamp...Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
dholmes, I have an 8 foot projection screen in my HT. I wanted something that:
*fact: over 60% of DVD sound comes fron the center channel*
(1) filled the screen in more (more sound spread across the srceen)
(2) just wanted more power and center channel presence so that images were more attached to the screen (coming out at ya)
(3) big complaint in ht > dialouge is not loud enough
My project solved all of these problems.
My center channel project had very little to do with a bass issue.would it be better to add a sub to make the center more beefy
More power and sound from the center - ya!
If your HT setup does not have a subwoofer yet. My suggestion is to go and get a sub before worrying about your center. The cs400 is a beast. If you don't have a sub you are missing out on the full HT experience. There are alot of low bass you are not getting. A good sub will add alot of sound, power, punch and oooomph you may be craving. Later!!! :cool: -
Thanks for the help scottvamp, I have 2, 200watt subs, placed in the front corners of the room,I recieved a free sub when I bought the rti150. I wanted to know if it would help the center spk to add a sub to it to give it more kick ThanksMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
3 subs in on room eh? lol! I wish I had 3 subs, Let me see here, 1 mx90-2 mx125s...LOL! newayz, u can plug the center up to the subwoofer, and try it - if you like it, keep it! lol!
If you dont know how - Run the speaker inputs on the sub to the outputs on the receiver (speaker wire) - then run speaker wire from the output on the sub to the speakers - i think I got the whole input, output junk right...this should add alot to ur center, but I shall warn u...it'll be hard to set upDamn you all, damn you all to hell.......
I promised myself
Two sub in the front corners of your room may be cancelling each other out. Multiple subs are very hard to setup and get to sound right. A sub setup on your center channel output would sound good but the placement for that 202 would have to be near the frontstage close to your center channel and with 2 subs up there already it may be a problem. But if you have the preouts - I would try it out. If the frequency on the sub is low enough not to pick up dialouge than there are plenty of effects and explotions on the center channel to give the sub a good workout. Later!!!!!Thanks for the help scottvamp, I have 2, 200watt subs, placed in the front corners of the room,I recieved a free sub when I bought the rti150. I wanted to know if it would help the center spk to add a sub to it to give it more kick Thanks -
Agreed!
HBomb***WAREMTAE***
