amplifier converted from 220 to 110- pitfalls?
GMiller
I've got a great deal locally on 2 Adcom GFA545's. Only caveat is that they were purchased by a serviceman overseas (Europe I believe) and he had them converted from 220V to 110V by an electronic shop when he returned stateside. Anything I need to worry about? Long out of warranty and currently set up to be listened to.
Post edited by GMiller on
If they work fine with 120 then they are fine. The transformers are capable of being wired for both voltages. No problem. BTW nice amps.
Ben -
Thanks! I'm working on a dedicated 2ch room and figured this would be a good start. Can't believe some of the finds on CL! NAD 1600 and these amps for less than a c-note apiece!
The only thing that needs to be changed is the power transformer.
Same performance, 99.9% of the time. -
Fuses should also be changed to the current level associated with 120V instead of 220V. If this hasn't been done already, contact Adcom to find out what they are.Brian Knauss
ex-Electrical Engineer for Polk -
Wouldn't a 4 amp fuse at 240 be the same as an 8 amp fuse at 120? -
240 must be from Britain or Australia.Most others atleast in Europe are 220-230.Testing
Testing
Testing -
Just wire in another power cable and plug it into a second outlet; problem solved!
Just wire in another power cable and plug it into a second outlet; problem solved!Testing
Testing
Testing
