Ps3 sd/dvd?
wingnut4772
wingnut4772 Posts: 7,519
edited September 2008 in Troubleshooting
Why is my PS3 only putting out a small rectangle version of my SD DVDs on my 60' screen? I want it to fill the whole screen....:confused:
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
  • hoosier21
    hoosier21 Posts: 4,413
    not sure if the PS3 has this feature, but your TV should have a stretch or fill option.
    It is currently showing the native SD picture.
    NOTE, if you stretch it to fill your screen, it will be a "stretched and distorted picture, may or may not bother you.
    If there is a "zoom", it is better, it zooms in till the screen is filled and cuts off the outer edges.
    Russ
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
